Reload this Page >
JL 1/8 F16 ARF accessories needed
Old 09-16-2007, 07:50 PM
Achillesfilho
Achillesfilho's Avatar
Default JL 1/8 F16 ARF accessories needed
Hi, anyboby can tel me which itens to complete the 1/8 JL F-16 ARF assemble.
Achilles.
Old 09-17-2007, 03:58 AM
jeff sewell
Default RE: JL 1/8 F16 ARF accessories needed
Hi,
Radio, turbine, fuel tubing, filters, offset hinges and sequencer, UAT, door cylinders...
Is this what you was looking for?
Jeff
Old 09-17-2007, 07:16 AM
Achillesfilho
Hi Jeff.
Thanks for answer.
Sorry ,i were not more specific.
Which gear cylinder door size?
How many gear door hinges i will need?
Bypass is needed?
What about wings horns and links?
Thank you once again.
Achilles.
Old 09-17-2007, 10:19 AM
drdoom
My Feedback: (9)
Wing horn's and Linkages are included,
you will need 3 Off Set hinges per door (3) = 9 hinges.
3 , 1 1/4 inch stroke Pnuematic cylinders,
UAT, JMP or BVM , Or others will work.
I used 3 air tanks. kit came with 1. so 2 tanks and 2 fill valves and a door valve. "T" Connectors.
You will need 2 miles of Pneumatic line. [X(]
5 36 inch extensions, 2 elevator. 2 wing and 1 rudder.
I used 2 Matchboxes, 1 on the elevator, and one on the rudder steering. If you don't want flaps You will need a Y for the ailerons.
I bought a bunch of metal servo horns.
Don't forget fuel line and a couple of "T" connectors.
There are other things as well.
Old 09-17-2007, 11:03 AM
Achillesfilho
Thank you drdoom.
Regards.
Achilles.
