10x Programming Help?
Hey,
I'm trying to set a condition on the 10x transmitter. The canopy is on Aux 4, and I'd like it to be 'dead' when the throttle is above idle. Is this programmable? I'm not really familiar with this Tx. Thanks in advance for the help/advice.
Shaun,
You can assign a mix to a throttle. Then you set the offset and anywhere above the offset point aux 4 will be inactive.
I do this with my nose steering using a switch so rudder inputs do not move the steering when retracted.
I can send the setup tonight.
