What jets do not tip stall?
![](/forum/images/badges/premium_member.png)
ORIGINAL: Synthetic
I was always taught that landing is a stall maneuver. If the landing is not at stall speed I would think you are forcing it to land. Of course you want to be a few inches off the ground when it stalls and not to high in the air.
Regards,
John
ORIGINAL: siclick33
What interests me with threads like this is the misunderstanding that many people have over principles of flight.
Not true. If you stall to land you are risking damage the aircraft if the stall occurs that little bit too high and you drop onto the runway. On a full size aircraft it is also likely you will get a wing drop which could be unrecoverable.
Technically the aircraft is not stalled in this condition. It is in 'ballistic' flight. Stalling occurs when the critical angle of attack is reached. This does not occur in a hammerhead.
All wings can stall. If not you can never land
Also if you do a Hammerhead, all aircraft will stall
The hammerhead is "Technically" called a Hammerhead Stall. It is called this because at the end of the manoeuvre, the aircraft stalls!
![EEK!](https://www.rcuniverse.com/forum/images/smilies/eek.gif)
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
180 degrees - Above the stalling angle? Below the stalling angle? Hmmm!
Rav, You are quite right. The best jets to avoid tip stalling are deltas and other low aspect ratio plan forms. Delta canards are especially good. However, plan forms that have LEX's, also can have somewhat similar characteristics to canards. Washout in the wingtip and the use of flaps for landing, will all reduce the possibility off a tip stall. Finally, have the cg in a safe position ( better a little nose heavy than tail heavy).
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (18)
MO
Thank you John! I was hoping I wasn't completely crazy! ![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
I thought when it wouldn't FLY anymore....it lands and hopefully it is very close to the ground when that takes place....
AB, CANADA
The only full size aircraft that you want to stall upon landing are small taildraggers. Even though you Cessna's stall warning horn may be blarring away, it most often is only approaching a stall condition. If you thump it in, well, then you stalled..ususally not a good thing. Bigger planes you fly them in...and use all the devices at your disposal (spoilers, chutes, reverse thrust, etc) to rapidly transfer the weight on the main gear....
Anyways...back to tip stalling.....
Not all deltas are imune.....I have Super Reaper that will tip stall..
#31
John,
I don't want to get in an argument. As you can see from my location I am not far from you and hope to be flying at Elvington soon. Hopefully we will be able to chat this over whilst we fly or over a beer![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
I don't believe that I need to reconsider. I would argue that the whole point in landing is to place the aircraft on the ground under control. If you stall 1 inch above the ground then that last inch is not under control. Not so much of a problem there but if you do it a foot off the ground then you may be in trouble. I prefer to land slightly above the stall speed so that I am always in control and thereby risk crashing (not that I can always do that
Regarding the Hammerhead (stall) turn, the name is a misnomer. I can categorically say the during a correctly flown stall turn the aircraft is never stalled. If you get a chance to fly it in a full size aircraft you will see that any stall warnings (stall warner, buffet etc) do not occur even though you are way below the stall speed.
What has this got to do with model jets? Well as suggested by Jascat at the opening of the thread, many models do not have great stall characteristics and heavily loaded jets are notoriously bad. I have seen many approaches flown where the wings are rocking on the way down as the model is being flown too slowly (the wing rock is sometimes telling you something
) with no concern from the pilot. I have seen many models stall and crash in the undershoot (fortunately not many jets).
How would you notice an approaching stall? What would you do if you find yourself in this situation on the approach? These are expensive toys and I think we owe it to ourselves to understand what they are doing in the air. As a result of this additional knowledge hopefully we can all fly better and make our investments last longer.
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
#32
No full size type that I have flown is stalled onto the runway, at least not intentionally. Light aircraft should be close to the stall when they touch down but not actually stall while still airborne. This is not because it is required in order to put it on the ground but to minimise stresses on the undercarriage. The plane can be landed perfectly well at higher speeds and less of a nose up attitude. Faster and heavier types eg fighters and airliners are safely above stall speed when they touch down. A stall is not required in order to put the plane on the ground, just a rate of descent.
John and siclick, you are arguing about different manouevres due to British and American terms. What we call a stall turn, the Americans call a Hammerhead. That manoeuvre is not a stalled manouevre. What we call a hammerhead is what the Americans would call the exit from a tailslide, which does involve being stalled albeit only very briefly.
Harry
Harry
#33
Harry C.
There is a possibilty of slight confusion but I am only aware of 2 types of Hammerhead. The stall turn and the Hammerhead stall (Humpty-Bump). Neither manoeuvres invlove a stall as far as I am aware. Maybe we should have this discussion on another forum?
#35
ORIGINAL: siclick33
Harry
#36
My Feedback: (8)
ORIGINAL: pantherflyr
What jet wont tip stall.........Just being funny but here goes!
A turboprop (in this case, a Cessna 208) is not a jet. BTW, I was a company instructor in Caravans in western Alaska and take it from one who knows..they will tip stall.
How's your beautiful family?
Bob
#38
ORIGINAL: siclick33
Harry C.
Harry C.
Aerobatic names are rather fluid, between countries and over time. But in Britain a hammerhead stall is generally meant for that part of a tailslide where the plane pitches rapidly from vertically up to vertically down, and thus for that second or so while it is pitching the wing will be stalled until the plane is nose down enough,
H.
#39
ORIGINAL: ianober
Exactly and Tams wont!!
ORIGINAL: Yann
Who said my F16 is tam's ???? Like only tam kits out the F16...
My F16 DOES tip stall and I was all sweaty when it happened (during the maiden).
Guy's, you cant apply a blanket statement that no F-16's can tip stall. Not all F-16 models are the same and one guy's wing might be cambered diffrently than the other's. What about the Kyosho F-16? I am prety sure I seen it tip stall.... and I'm pretty sure a hammerhead is in a stall when the definition is the cessation of generated lift.
#43
FL
the super reaper is a Mick Reeves Models kit and is very affordable . The turbine in mine is a behotec 130. and good looking with no tip stall
#44
My Feedback: (251)
HI all, on my first Bobcat, i moved the CG so far back, it would wing rock on landings, ready to stall, so I knew not to go any further back.
On my second bobcat with the CG, 1/4'' behind the recommended CG, I purposely flew it around to see how slow it would fly and on final with a cross wind over the trees, it snapped and luckally, I was high enough to save it.
Lesson, you have to watch out for that cross wind.
Rcpete
Rcpete
#45
My Feedback: (32)
So many experts,with so many opinions.Truth is ,any conventional airplane will tip stall at a high enough AOA. Most canard designs will not,because the canard will stall before the wings critical AOA.If you pull enough g's any conventional airplane will tip stall.Someone made references to delta's being benign.Anyone who has flown an old school yellow A-4 will tell you that is not necessarily the case.WFO,on the step,you can pull enough g in a turn with that airplane to make it tip stall.It is purely a function of wing loading,and bank angle will increase that number exponentially.Everyone who mushed their F-16,did it wings level,or close to it.I can tell you that at 180 knots,it takes 25% more power to hold airspeed in a DC-9,with a 20 deg bank angle,than straight and level.
If you're concerned with your ability to recognize the onset of this condition,stay with the more benign designs.Go find out for yourself,and take all the opinions with a grain of salt.Good luck.
Erik
Erik
#46
Erik,
Funny you mentioned the Yellow A-4. It's a good example of what a tip-stall looks like. That plane, when at the stall angle, would tip out pretty abruptly. With enough speed (and, by extension, G-forces) in a turn, the angle could be reached with too much elevator and high-speed tip it. That looked scary!
When I was first cutting my jet-teeth, Buck (aka Yeahbaby) was showing me the ropes on A-4's and once said, "uhh...ur pushing the high-speed departure, bro" and then I thought to myself "whatever, dude...I'm fine...." Right about that time, I did a power-dive and yanked up on it and it high-speed stalled! Craziest stall I ever saw. I looked over at Buck--who didn't say anything--he just kept his gaze upward but had that little grin going... After that, I pretty much listened to everything else he had to say about flying that plane!
When you learn where the stall angle is, it's the funnest little jet in the world.
#47
My Feedback: (12)
ORIGINAL: Goin West
Ianober, I think you can turn a discussion about transsubstantiation in Marxist Cuba into a Tam ad. Do you ever get tired of it? Just this once let them have their debate about stall characteristics in planes in general without all the gasbaggery, eh?
ORIGINAL: ianober
ORIGINAL: Yann
I would say my responses were quite smalll for a gasbag, however the one above I think would qualify.
Call it an ad if you wish, but its just the truth. And I believe the thread topic was "What jets dont tip stall?", this is one, so please don't hate.
#48
Can you please explain how an aerofoil is stalled when it is not creating lift? I think I am missing something here.
#49
ORIGINAL: siclick33
#50
As per Chalkjim,
Mick Reeves Super Reaper,it will stall,but not tip stall, but you have to be going so slow that it will fall out of the sky.
It will hover in a 5mph plus head wind.![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Which when you see it hovering/staying still in flight takes some believing,then open the throttle & go vertical,allways amazes onlookers.
All the best,
John C
All the best,
John C
