Skymaster F14 Tomcat
#703
My Feedback: (40)
This might be getting closer now.
[TABLE="width: 396"]
[TR]
[TD="class: xl66, width: 125, bgcolor: transparent"]What (Revised 1)
[/TD]
[TD="class: xl67, width: 102, bgcolor: transparent"]Channels that can be used
[/TD]
[TD="class: xl67, width: 111, bgcolor: transparent"]Channels really Required
[/TD]
[TD="class: xl67, width: 77, bgcolor: transparent"]Amount Servos
[/TD]
[TD="class: xl68, width: 112, bgcolor: transparent"]EQUIPMENT USED
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]elevons
[/TD]
[TD="class: xl64, width: 102, bgcolor: transparent"]2
[/TD]
[TD="class: xl64, width: 111, bgcolor: transparent"]1
[/TD]
[TD="class: xl64, width: 77, bgcolor: transparent"]2
[/TD]
[TD="class: xl70, width: 112, bgcolor: transparent"]JR DS8911
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]rudder
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]steering
[/TD]
[TD="class: xl64, width: 102, bgcolor: transparent"]1
[/TD]
[/TD]
[TD="class: xl64, width: 77, bgcolor: transparent"]1
[/TD]
[TD="class: xl70, width: 112, bgcolor: transparent"]JR DS8511
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]flaps
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]spoilers
[/TD]
[TD="class: xl64, width: 102, bgcolor: transparent"]4
[/TD]
[TD="class: xl65, width: 111, bgcolor: transparent"]MIX WITH BRAKES AND MIX WITH ELEVONS
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]slats
[/TD]
[/TD]
[TD="class: xl64, width: 111, bgcolor: transparent"]MIX WITH FLAPS
[/TD]
[TD="class: xl64, width: 77, bgcolor: transparent"]4
[/TD]
[TD="class: xl70, width: 112, bgcolor: transparent"]JR DS3421
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]hook
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]throttles
[/TD]
[/TD]
[TD="class: xl64, width: 111, bgcolor: transparent"]2
[/TD]
[TD="class: xl64, width: 77, bgcolor: transparent"]0
[/TD]
[TD="class: xl70, width: 112, bgcolor: transparent"]ECU X 2
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]cockpit open and locking mechanism
[/TD]
[/TD]
[/TD]
[/TD]
[TD="class: xl70, width: 112, bgcolor: transparent"]2 x AIRPOWER EV2U
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]swept wing
[/TD]
[/TD]
[/TD]
[/TD]
[TD="class: xl70, width: 112, bgcolor: transparent"]2 X ACTUATORS INCLUDED
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]gear
[/TD]
[/TD]
[/TD]
[/TD]
[TD="class: xl70, width: 112, bgcolor: transparent"]AIRPOWER EV2U
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]rear speed brake
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: xl69, width: 125, bgcolor: transparent"]gear doors
[/TD]
[/TD]
[TD="class: xl64, width: 111, bgcolor: transparent"]0
[/TD]
[/TD]
[TD="class: xl70, width: 112, bgcolor: transparent"]2 X AIRPOWER EV2U
[/TD]
[/TR]
[TR]
[TD="class: xl71, width: 125, bgcolor: transparent"][/TD]
[TD="class: xl72, width: 102, bgcolor: transparent"]21
[/TD]
[TD="class: xl72, width: 111, bgcolor: transparent"]11
[/TD]
[TD="class: xl72, width: 77, bgcolor: transparent"]14
[/TD]
[TD="class: xl73, bgcolor: transparent"][/TD]
[/TR]
[/TABLE]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
Since there is only one throttle stick/control, how do you intend to use two channels on throttle? Just curious.
Craig
#704
Hi Craig,
I was thinking Throttle and an AUX channel mated, using a 3 way switch to start each engine separately. Haven't tried it yet, just a thought so far.
#706
My Feedback: (40)
Craig
#707
Hi Bart,
I am expecting it for my 50th birthday in February. The wife has the quote from SM and fingers crossed it's happening.
I will post the throttle idea / mixing, when I have a chance to emulate it on the test bed shortly Craig. Should be something in there that will work. I have done this previously for twin gas engines on a 3 pos switch. just have to nut it out for the trim up requirements of the turbines probably. Time will tell.
#708
On my other twins ( all Jetcats) I used to do the one immediate and other sequential as Ivan pointed out but have now changed them all over to both start at the same time as they are just so reliable. Best investment I ever made though is fitting the mini gsu's on board each plane so you can clearly see ignition and spool up.
#710
My Feedback: (16)
On my SM A-10 the throttle connection to each ECU goes to an individual switch. The switch wire then goes to a Y which then goes to the throttle "channel" on the Powerbox. During start, I turn the right engine switch off, the left engine switch on. Start the left engine, then turn the right engine switch on and move the throttle stick full up then full down. The right engine then begins the start process. It interrupts the signal, not the power.
#722
Okay just seems like a quick easy layup to complete the ordnance. Well let us know when you do, im going to wait on that. Everything else looks really good so far it will be nice to hear from people once they start flying their 14s.
#724
Interesting idea with potential if you have the extra channel. You would have to figure out a mix setup that will "hold" the non-starting engine at idle while you start the other. It's good to be able to shut down the second engine without shutting down the first, in case you get a bad start and want to try a restart. I accomplish that on my A-10 by momentarily disconnecting the ECU battery but the two channel method might also work. Good luck figuring that out.
Craig
Craig
Zb
