Reload this Page >
Skymaster F14 Tomcat
Old 01-07-2015, 03:35 AM
  #1301
WimB
WimB's Avatar
Keith,
you're right... The D has the two screens side by side. the RIO panel also has a CRT screen in the upper middle of the panel, above the round radar scope, and the MDI screen on the right knee panel.
Wim
Old 01-07-2015, 03:45 AM
  #1302
WimB
WimB's Avatar
I must admit I did cheat on mine.... although it's a "B", I did install the "D" double chinpod.... looks meaner in my book.....
W.
Old 01-07-2015, 07:22 AM
  #1303
muzzgail
muzzgail's Avatar
I am hoping to fit a camera lense into my chinpod for flight recording and of course it would look soooo cool
Old 01-07-2015, 07:29 AM
  #1304
muzzgail
muzzgail's Avatar
For those building this beast, of note, the rudders on mine had to be done twice. Unless you get the carbon rudder horns all the way to one side of the rudders, there is movement when the rudder servo is centred. It is a bit of dremelling to get the meat out of the rudders, but get the horns set all the way to one side and you won't have slop in the linkage setup. It needs the angle from servo to horns for it to hold when centred, otherwise it teeters over centre and you can move the rudder......possible cause of flutter if not done right I guess.
Old 01-07-2015, 11:34 AM
  #1305
WimB
WimB's Avatar
Murray, the rudders are a pain indeed.........
Wim
Old 01-07-2015, 11:47 AM
  #1306
FenderBean
FenderBean's Avatar
Muzz any chance for a photo showing what needs to be done?
Old 01-09-2015, 06:53 PM
  #1307
PowerBoxDanny
My Feedback: (47)
PowerBoxDanny's Avatar
Good to know! I received the Nose box of my plane today. Wednesday I go get the large crate. I am excited and so far it looks awesome. I can see why this bird is pricey. Great job so far Anton!!!
By the way, can one of you tomcat owners tell me how to unlock the landing gear to raise it back into the fuselage without air hooked up? Put it all the way down and seems like it locked. Totally dofferent setup than I have seen in my years of building.
ID:	2062622   Click image for larger version
Old 01-09-2015, 07:58 PM
  #1308
FenderBean
FenderBean's Avatar
Hey skunk can you post a picture of your rudder control surface? Does yours have any rudder control horns installed?
Old 01-09-2015, 08:11 PM
  #1309
PowerBoxDanny
My Feedback: (47)
I would but I don't have that yet. I only received the nose box today. Wednesday I'll get the rest and post some pics.
Old 01-10-2015, 02:03 AM
  #1310
Aussie Bart
Aussie Bart's Avatar
Well I am pleased to say that after a concerted effort over the brief xmas break I have finally finished my 14. I am really happy with the way the gear works after fitting dual air valves and a meter out restrictor, plenty of grunt and great authority. I have fitted a Carsten Groen ASSI unit along with screen and a second Can LCD screen. Needed 200 grams of lead in the nose so I reckon I got the layout right. Found space behind the cockpit sides for the header tanks which are High Flow and fitted with 6mm tube all the way back to the fuel pumps. Next opportunity to do the maiden will be March at the VJAA club day at a full scale airport. Been this long now, another couple of months won't matter.
ID:	2062667   Click image for larger version
ID:	2062668   Click image for larger version
ID:	2062669   Click image for larger version
ID:	2062670   Click image for larger version
ID:	2062671   Click image for larger version
ID:	2062672   Click image for larger version
ID:	2062673   Click image for larger version
ID:	2062675   Click image for larger version
ID:	2062676   Click image for larger version
ID:	2062677   Click image for larger version
ID:	2062678   Click image for larger version
ID:	2062679   Click image for larger version
ID:	2062680   Click image for larger version
ID:	2062681   Click image for larger version
Old 01-10-2015, 03:01 AM
  #1311
Springbok Flyer
Springbok Flyer's Avatar
Shane,
That was quick work indeed. Looking good mate. Let us know how the maiden goes - would be good to have yours and Colin's at the QTFly-in this year.
Cheers,
Jan
Old 01-10-2015, 07:04 AM
  #1312
PowerBoxDanny
My Feedback: (47)
That's awesome! Those pics will be of great help and ideas! Thanks!
Old 01-10-2015, 07:34 AM
  #1313
FenderBean
FenderBean's Avatar
Grats man looks good, is the restrictor on the out to slow the gear down? Wait are you gear hydraulic?
Old 01-11-2015, 01:38 AM
  #1314
Levi Wags
Levi Wags's Avatar
Your a legend Bart. World class.
Old 01-11-2015, 06:24 PM
  #1315
muzzgail
muzzgail's Avatar
Well done Bart. You have made a beauty there.
Old 01-12-2015, 12:19 AM
  #1316
WimB
WimB's Avatar
Danny,
No way to unlock it without air, The downlock is air operated. Just connect your handpump to the 'up' side of the cylinder and give it some pressure. You will probably need to push back on the nosewheel to make the pin unlock. Don't worry, once it's all hooked up, it works like a charm.....
Wim
Old 01-12-2015, 12:31 AM
  #1317
muzzgail
muzzgail's Avatar
Hi Keith, I didn't take any photos of the rudder horn installation. Sorry.
Old 01-12-2015, 12:37 AM
  #1318
muzzgail
muzzgail's Avatar
But I did find these photos that I think will show you what I mean when I say, get the horns to the side of the rudder as much as you can.
Name:	Wing and Stab Bag.jpg
ID:	2063244   Click image for larger version
Name:	Rudder Horn Placement.jpg
ID:	2063245   Click image for larger version
Name:	Rudder Horn Placement 2.jpg
Old 01-12-2015, 12:39 AM
  #1319
muzzgail
muzzgail's Avatar
Here is the picture of the bag I received to hold both wings and both elevators.
Old 01-12-2015, 02:00 AM
  #1320
kcmj
kcmj's Avatar
Hi All
A Couple of update pics of the cockpit. Had fun today experimenting with the working HUD. I know it is stuck on with blue tack but you have to start some where. The HUD you see in the pics is not the one going in the plane. There are a lot more gauges still to be fitted. This is just the top section of the front cockpit dash.
Regards
Keith
ID:	2063258   Click image for larger version
ID:	2063259   Click image for larger version
Old 01-12-2015, 02:10 AM
  #1321
WimB
WimB's Avatar
Super!!!
W.
Old 01-12-2015, 02:23 AM
  #1322
kcmj
kcmj's Avatar
Thanks Wim
Old 01-12-2015, 07:39 AM
  #1323
muzzgail
muzzgail's Avatar
Nice stuff Keith. You are on track for a show stopper mate.
Old 01-12-2015, 03:15 PM
  #1324
FenderBean
FenderBean's Avatar
Thanks muzz, I talked to John they are going to send me the control horns with my other replacement parts. The bags are out of stock once they arrive in they are suppose to send them to the people who did not get them with their kits.
Old 01-12-2015, 06:17 PM
  #1325
PowerBoxDanny
My Feedback: (47)
My big box is here, I will go get it tomorrow! I will post some pics.
