Skymaster F14 Tomcat
#1681
Hey everybody, how's your experience with the SM pistons?
I'm finally getting around to installing the air system and I m considering what to do.
Is it worth it to try and pressure test these, eventually replacing o-ring? Or is it just a waste of time?
What is everybody using in theirs?
I pulled mine, water tested them all, and fixed a few that leaked. Reinstalled and still had leaks, so I replaced all of them except the canopy and speed brakes with ultra precision. The speed brake still leak some but they are never used and not part of the gear or doors so I haven’t bothered to change them. Save yourself the heart ache.
#1683
I took some time today to try and fix them. The bigger ones look like they can sorta be reliable, but the smaller ones are not designed well. The head where the shaft comes out doesn't seem like it can possibly seal well as the o-ring seat is too small and is just slides away.
I'll look into the UP cylinders. Are these good?
#1685
#1686
#1687
#1689
My Feedback: (22)
Does the F14 fly poorly with wings swept? In all the videos I've seen of the jet it seems nobody does much with these wings swept back. A pass with maybe a roll and then sweep them out again. Not that I'll probably ever have one but the F14 is my favorite jet and the wings swept back is a huge draw for me.
Woketman (05-09-2020)
#1693
I installed Kingtech 85 without thrust tube, made all wires new and light weight, fuelbag from fuelbag.de, EVERYTHING is installed under the nose cone and just behind it, small servos for slats, rudders and spoilers and only 3 litres fuel :-((( That lasts for 4 minutes from gear up to gear down. After 3 flights I'll adjust the gyro (cortex pro) on the next flights and reduce the throws when the wings are swept back.
The kit was standard manufactured and is much too strong for the F-14 light I made. But I think, I'm the only one. If we don't have the 25 kg limit in Germany, I surely had installed 140 or 160 engines.
Karl-Andreas
Germany
Karl-Andreas
Germany
#1694
Karl-Andreas
Germany
Karl-Andreas
Germany
Thanks mate
Levi
#1695
Fuelbag
Hello Levi,
the fuelbag is made of four layers of plastic film and weighs only 120grams inclusive inner filter +two carbon tubes for installing. Another filter is no nessecary. In my models the fuelbag is located at the CG and the 6 mm Festo tube goes directly to the in the nose cone (more than 1 metre). In the german homepage they say, that a customer (or test pilot) had more than 1000!!! flights with any problems. I like „bubbles“, because of the low weight an easy installation, it‘s absolutely clean, doesn‘t smell and a hopper tank isn‘t needed. I hope you understand my english 🙈
Best Regards
Karl-Andreas
Best Regards
Karl-Andreas
#1696
Hello Levi,
Best Regards
Karl-Andreas
Best Regards
Karl-Andreas
Cheers
Levi
#1697
Hello Anton,
thank you very much for making my boy dream come true! The TOMCAT flies like a dream and as if on rails. 2 x Jetcat P180RX, Powerbox ROYAL and Futaba FX-36.
Marco from Switzerland
blackcat (11-27-2022)
#1699
Any thoughts or experience on how a twin 140 setup would handle in an engine out scenario? Ability to maintain level flight around the pattern for a single engine landing?
how about the can diameter of the turbine in terms of the installation? I’m also considering twin 190’s that are each 110mm width.
