 CA On Plane - How To Remove? >
Old 11-24-2007 | 09:58 AM
My Feedback: (18)
Default CA On Plane - How To Remove?
If a person were to accidently get some thin CA on a composite surface and on a Mono-Coat type surface..is there way to remove it?
Thanks...
I am asking for a friend as I would not be crazy enough to let this happen to me....maybe...Hehehehhehe....
Old 11-24-2007 | 10:05 AM
rcguy!'s Avatar
My Feedback: (69)
Default RE: CA On Plane - How To Remove?
Debonder!
Dave
Old 11-24-2007 | 10:43 AM
My Feedback: (9)
Acetone will. But if it is painted you can't . It will remove the paint. OK for Monocote.
Old 11-24-2007 | 10:51 AM
c/f
Ca debonder in the purist form for industrial use is 100% nitromethane. Just ask for a MSDS sheet, Those for model use are mostly nitro cut with acetone, not so good IMHO.
I routinely remove Ca on monokote and painted surfaces very carefully using the Golden West Debonder brand found at woodworking stores.
ie. http://woodcraft.com/family.aspx?fam...e=details#tabs
Old 11-24-2007 | 10:54 AM
Soak a paper towel with unburnt glow fuel, the more nitro the faster it will work. Let sit for 15 minutes and it will wipe right off.
Old 11-24-2007 | 11:15 AM
My Feedback: (18)
Thanks guys...great ideas and will give them a try. I appreciate the help! Errr....I mean....my friend appreciates the help!
HEHHehehehhe....
