Double tank trouble
Double tank trouble
Hello guys... this is the problem: I'm being forced of putting two tanks in my plane; how can I be sure of burning the fuel uniformely; mean: not to use one tank entirely (and receive an engine shut) while the other is still full...
Other usefull information:
- Each tank is 3 lts (almost one US gallon).
- Separation between them is about 80 cm (tip tanks).
Can anybody send me a usefull-practicable layout?
Thanks on advance
Guille
Thanks on advance
Guille
RE: Double tank trouble
OK Mick; I thouth on that but the problem is to not have a wing tip "full" and the other "empty"... I'll have three litters at rigth and none at left. They must remain more or less equilibrated.
It's a kind of Mig-21 but It has to flight for a long time and fast (a couple of hours or more if possible). The Fuselage comes a 100% for the turbine servos and betteries and the fuel will be on the underwing tanks (3 lts each).
Thanks for your interest...
So a 32" wingspan with a US gallon on each wing tip and a 2-hour flight time... Good luck to you. If you are serious then I think your best way would be to draw from these tanks in parallel with equal lengths pipes on the vents and feeds, this will ensure that the balance remains correct and both tanks fill and drain at the same rate.
Jason
Jason
My Feedback: (10)
ORIGINAL: jason
Jason
Jason
not only that , you need to fly the same laps right side and left hand side...
No no... I used the term wing tip tank for a quick understanding. Fuel tanks are partialy under the wing and partially on the wing. There is U2 with more or less the same configuration: http://www.aviation-central.com/1946-1970/afka0.htm
Real wingspan is about 2 meters.
I've gotta ask, what turbine is gonna fly this two meter plane for two hours on a gallon of fuel??? i need a few of em because these blasted JetCat's are killing my mileage.
My Feedback: (24)
Just do as Jason suggested above however, I would cross vent. Make the left wing vent to the right wing and the right wing vent to the left. Have both tanks drain to a center header.
Todd
Todd
My Feedback: (48)
Here's a schematic of a typical parallel tank set-up. Take care to insure that each tank's plumbing, including the tubes and clunks inside the tanks, are identical. That will insure that they will drain and fill close to the same.
After plumbing my tanks I always drain and fill them several times using my fill station as a check. Shorten the lines to the tank that drains/fills the slowest a little bit at a time until you get them about equal. Don't waste your time trying to get them exact, if they are within a couple ounces of each other you are good.
Joe
Joe
Just to update you guys...
tests with the double tanks went really good considering the advices you gave me... I received a decently equilibrated fuel consumption on my on ground test dispositive. in-fligth test will take place in a couple of weeks.
Thanks again
Guille
Thanks again
Guille
My Feedback: (18)
MO
Guille,
Can you tell us how you will be able to fly for two hours without refueling in air? Myself, I am not sure how this can be done unless you pack in a lot more fuel than two gallons. You've got me me curious.
Thanks and Good Luck,
Don
Don
IL
In a turn the gas should be sitting pretty much in the same place as it sits in level flight.Just like "the ball", slip indicater on full size aircraft stays in the center during a turn.The high g's of jet flying would even keep the gas planted in the bottom of the tank.
ORIGINAL: flyexperimental
the flight of an RC plane is far from perfect coordinated turns and the fuel is constantly in motion moving around the tank, even sloshing violently.
IL
Both tanks,even if they are not sitting next to each other are affected by forces equally .I can not see turning more in one direction,verses the other will make one tank drain quicker than the other.If the tanks drain evenly while sitting still they should do the same in flight.When the fuel does get tossed around it will do so in both tanks.
