air cylinders
MI
air cylinders
i am working on tf b-25 and wish to actuate my bomb bay with air cylinders. I know you guys use them for gear doors all the time. the 25 is 1/9 scale. What type would you guys use
MI
RE: air cylinders
they need to be small diameter and the problem is i am not sure of piston stroke and have no way to adjust these like i do with a clevis. unless im missing some info on these small cylinders
RE: air cylinders
TamJet is another good source for the cylinders. on the stroke you can either do some massive trig calculations or just install the hinges and measure the stroke required and add a mm or two so it has some extra pull on the door when fully closed.
WA
RE: air cylinders
A lot of door hinging is trial and error believe it or not. If you use Tamjets style offset hinges you can use the short BVM cylinders and attach them to the horn and be close. I designed a custom horn that allowed me to utilze the long BVM cylinders on my Phoenix gear doors. I am pretty sure that this set up is what you are looking for. I will shoot you some pics, if it is what you are looking for, I will laser cut you some mounts and mail them to you.
Chris
Chris
WA
RE: air cylinders
Here is what I am talking about. You can play with the cylinder body position to tweak how far the doors open. Let me know if you need more help, I have LOTS of experience hinging doors and would be more than happy to help you out. I have a soft spot for the B-25!!!
Chris
Chris
RE: air cylinders
If the stock units from BVM, Tamjets or other RC sources don't work for you, look at the industrial stuff form e.g. Clippard : http://www.clippard.com/cylinders/Default.asp - I've use the minimatic cylinders a couple of times.
MI
RE: air cylinders
thanks guys strato im using nelson hinges and they work perfectly at hinging a b-25 bay. ill post pics here. Wow i was told not to ask here cause jet guys wont be of much help im glad I didnt listen!!! thank you guys
RE: air cylinders
You can also mount the air cylinders at 90 degrees and use bellcranks, then you can adjust the final stroke by moving the clevises on either side of the bellcrank. This is what I did on the main gear doors of the Gripen I am building right now. I can post some pics later today (when the clear is dry enough that I can re-assemble it) to show how it works.
Or, if the stoke of the air cylinder is too long you can put a wheel collar on the shaft to use as a stop. I don't like doing this though because the air cylinder will never be able to be used for any future applications if it requires more stroke than you have limited it to.
MI
RE: air cylinders
heres what i have please post your pics! the hole in the middle of the bay is where my lipos go 7s each side! it has a complete bomb bay. the area with all the scale wiring up front is completly accesable from the other side. any pics or diagrams and sizes of cylinders would be appreciated
WA
RE: air cylinders
I machine spacers that float on the cylinder shaft and limit travel to the desierd dimension. When you choose a cylinder and figure out if you need spacers, I can whip some out for you if you do not have access to a lathe. Would only take about twenty minutes for a basic spacer.
Chris
Chris
MI
RE: air cylinders
no lathe. ive been building and flying for 25 years but never used small cylinders for bomb bay or door operation till now. ill give you the measurements and you can tell me the kind of small cylinder i need .
pics of installation would be helpful too
WA
RE: air cylinders
as far as the cylinder spacers go, you can use lengths of brass or copper tubing. I would go with the long BVM cylinders if I were you, it will give you a little more wiggle room in your install and will save a lot of headaches!!!
Chris
Chris
MI
RE: air cylinders
oh come on what a dream job! how about a tour if i come out there! i always travel to see my daughter. Do you get to fly in them working on the feft main! dual double tandem setup. im envious
WA
RE: air cylinders
I get lots of flight time in them. I even have simulator time, I get to fly around when I get tired of engine run practice. Lots of FUN!!!! You come up to Spokane and I will show you a jet!
Chris
Chris
MI
RE: air cylinders
interesting idea! how fast do your jets fly? Are there any that fly under or at 80mph. i always wanted a pcm L1011 but hes not in buisiness. Im 47 and cant keep up with 150mph airplanes. tried it once on a F-86 i slowed her down to where i could handle her and the landed! My bud showed me the high end performance and there is no way i could keep up with it. Looked like a streak!
