Reload this Page >
BD-5J Project
BD-5J Project
Old 12-09-2010, 07:07 PM
  #126
aapanama
Default RE: BD-5J Project
the keroseme tank that came with my BD-5 (James Bond) is 3 liters or 108 Fl. onces greetings from Panama
Old 12-14-2010, 02:29 PM
  #127
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
Wooo Hoooo.. got email from BVM: Expect delivery in 2 - 3 weeks!!
Old 12-14-2010, 07:00 PM
  #128
Doc...
Hi Frank:
I hope the info you received is correct, I really do, but please remember they shut down at the end of the month for 4-5 weeks for Chinese New Year. I hope they plan on having all the orders shipped by then..Good luck!!!!!!
Doc...
Old 12-15-2010, 05:15 AM
  #129
zonker123
My Feedback: (21)
zonker123's Avatar
ORIGINAL: Zagzoo
Frank
I was told 3 weeks ago that I would see mine in 4 weeks sooooooooo
Maybe you are getting mine.
Or
Maybe I am getting yours.
Maybe we will be celebrating the Chinese new year BD-5 less.
Hoping for the best, prepared for the worst.
Good luck to both of us.
Mike
Old 12-15-2010, 02:34 PM
  #130
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
ORIGINAL: zonker123
ORIGINAL: Zagzoo
Frank
Or
Mike
Well.. (#1) there was a cut off day for orders that WOULD BE shipped before chinese new year (which I know I was before) and (#2) Mine was probably the last box to go in the big cargo trailor to be put on the boat for the USA.
Old 01-03-2011, 04:55 AM
  #131
Doc...
Hi,
In looking at your pictures, I'm wondering if you have installed the metal pipe yet. In most of the BD-j5's I have seen the exaust end on the Jet have been cut since the pipe is not designed to go all the way to the end. As an example, stop the video in front of you when the Jet is talking off and you can see what I mean.
http://www.youtube.com/watch?v=AbK9N_BlALM
If this link doesn't work, I'll re-sent it.
Doc...
Old 01-10-2011, 05:25 PM
  #132
aapanama
Here are a couple of photos of my BD-5 (James Bond) with all the graphics, I am starting to install all the linkages for ailerons, flaps. steering, elevator and rudder. also I started on the turbine..
ID:	1545516   Click image for larger version
ID:	1545517   Click image for larger version
ID:	1545518   Click image for larger version
Old 01-10-2011, 05:39 PM
  #133
aapanama
two photos of my BD-5 at an airshow exhibition.. AAA
ID:	1545520   Click image for larger version
Old 01-28-2011, 06:04 PM
  #134
moki180
moki180's Avatar
Today I was pleasantly surprised when my bd5 arrived today which is now sitting on my kitchen island,its been a long 4 months . I been following the forum for awhile and noticing that the finishing instructions aren't being publicized or posted due to the lack of instruction that came with the plane.I understand , but any info or pics on what other modelers have done would help, so I'm not re-eventing the wheel on save on some time on finishing for the spring.
thanks frank
ID:	1554836   Click image for larger version
ID:	1554837   Click image for larger version
Old 05-17-2011, 09:33 AM
  #135
Todds Models
Todds Models's Avatar
My BD5 arrived yesterday. Just a quick look over and it looks good. One question, only one hatch on the bottom of the wing for the aileron servo. Where does the flap servo go?
Old 05-17-2011, 07:42 PM
  #136
zonker123
My Feedback: (21)
zonker123's Avatar
ORIGINAL: Todds Models
If you look at the root end of the wing you will a hole recessed in the wing for the flap servo. I hope to maiden mine next week. In an earlier post the C/G is stated at 4-3/4 from the root. Would appreciate confirmation if some one could confirm. It looks about right since thats approx 25% of the wing cord. Appreciate any input.
thanks
mike
Old 05-18-2011, 05:55 AM
  #137
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
ORIGINAL: zonker123
thanks
mike
Mike, here is the info from another xtreme BD thread:
Score: 100
Last Login: 5/14/2011
Status: offline doc: I am builiding a BD-5 from extreme... a fellow that goes by the name dirtydingus has built one and flies very neat.. he sent me the following information,, maybe it can help`you I hope..
ELEVATOR 5/8 INCH UP 5/8 INCH DOWN
AILERONS 3/4 ¡NCH UP 3/4 INCH DOWN
RUDDER 1 INCH LEFT 1 INCH RIGHT
FLAPS 1 AND 1/4 INCHES DOWN
CENTER OF GRAVITY 4 AND 3/4 INCHES BACK FROM LE AT ROOT
GREETINGS FROM PANAMA REPUBLIC OF PANAMA
IF YOU CAN SEND ME SOME PHOTOS THEY WILL BE HELPFULL...
Hide Signatures
Old 06-01-2011, 03:28 PM
  #138
Todds Models
What was the total weight of the BD5 when done? Just weighed mine as it comes out the box and it is a whopping 16 pounds. Mine is unpainted so I am guessing about 25 pounds ready to fly....??? Seems a bit heavy.......
Old 06-03-2011, 08:42 AM
  #139
Doc...
Hi,
That's about right. 20-22lb thrust engine should do well. Figure with the fuel tank it comes with, the weight on that full is about 5-6 lbs.
Doc...
Old 07-15-2011, 02:21 PM
  #140
Todds Models
Okay I have found some time to start working on my BD5.  My version came unpainted with  nothing installed. Just plumbed the retracts and was wondering how the nose wheel steering worked. Went through the box and found no mounting hardware for the steering servo or linkage. Looks like it uses pull - pull cable.
If anyone could post a quick picture how it is set-up I would appreciate it.
Todd
Old 07-15-2011, 02:25 PM
  #141
Todds Models
Oops, looks like aapanama has a picture in post 109
Old 07-31-2011, 02:20 PM
  #142
Todds Models
Been working on my BD5 for a few weeks. Here it is in mostly white primer with a little color.
Done all the mods, thanks Zagzoo for helping.
Old 07-31-2011, 05:22 PM
  #143
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
That paint job looks sweet. Here is the link to the mods to the BD5:
[link=http://www.rcuniverse.com/forum/m_10634311/anchors_10634311/mpage_1/key_/anchor/tm.htm#10634311]BD-5 Mods[/link]
Old 08-04-2011, 01:00 PM
  #144
Todds Models
Here it is with some color. And yes it was painted outside in a sand storm with finger paints.
Old 08-04-2011, 01:43 PM
  #145
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
That looks really good!
Old 05-18-2012, 07:07 PM
  #146
pilot tw
Hi, all
Skymaster/ Xtreme jets will release the G2 Bd-5 by new materil Airex, the new G2 version will be 1kg light than the old version,
Best regards
Anton
Old 06-07-2012, 06:37 AM
  #147
FormerCA.
My Feedback: (8)
Ordered my Skymaster BD5 Silver Bullet thru Hobbies Xtreme in Bossier City Louisiana. Also ordered a Jetcat p100 for power. Will let you guys know how it goes.
Old 06-07-2012, 05:32 PM
  #148
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
ORIGINAL: FormerCA.
Hope it is improved.. enjoy the wait!
Old 06-12-2012, 06:42 PM
  #149
FormerCA.
My Feedback: (8)
Anton
Did you guys address some of the issues with this kit in the Gen 2?
Ron
Old 06-12-2012, 06:49 PM
  #150
FormerCA.
My Feedback: (8)
I guess so right? I have always admired this plane, like most of us have, since seeing it in action in the James Bond film. I saw one video of the plane at some airshow and it looked like it handled pretty good, good manners on landing and such. Straight wing with flaps usually equals good flying characteristics.
