A Couple of Little Wrens
Banned
1 Post
RE: A Couple of Little Wrens
Got to go to work today what a bummer............... Should be able to get the test runs done this weekend and will post some info
Dennis
www.densplanes.co.uk
Dennis
are you gonna also run them on the dining table. it may be wise to move the table cloth first. dont want to get in trouble with the wife
Banned
1 Post
Hello all
We have now run up both of the little wrens and all went well. A couple of points to be aware of:
1) Make sure the wire is pulled out on the glowplag a good 2mm as our first one would not start immediatly but that soon fixed it
2) We also found that we needed to crank the glowplug power up to about 42 from the factory setting of 35..
By the time we got the second one running it was starting to get dark and my goodnes the tail cone glows at WOT mind you temp was only reading 600 degrees and with a top temp of 800 I was happy with that.
Generally very please now on to getting on with the plane build
Dennis and Pete
Dennis and Pete
