Composite ARF Lightning with AMT Olympus HP?
One of my flying buddies had one with a Olympus HP.
The performance was awesome to say the least. I do think the engine was a little starved for air by the small intakes, so static thrust may have been a bit lower.
I would be carefull pushing the stick fully foreward during level flight as that much thrust may result in a sudden cloud of dust....
My Feedback: (44)
I was told by composite ARF rep and by someone else that the Oly is too much for the Lightning due to extra fuel weight that you have to carry and the plane does not really need it. It was designed for constant speed aerobatics not for top speed. I almost installed an Oly in mine, but changed my mind for a Titan class engine. Mine is 80% finished and I'll be happy to share my findings when done..
You are right about that it doesn't need an Olympus. But it will handle a Oly if you don't use all the thrust for speed. I have a Merlin 160 in mine, and I think it's all it needs. The two main tanks holds 6 liters, and that is plenty for the Oly.
The friend I am refering to with the Oly. powered Lightning is a rep. himself.
My Feedback: (27)
GA
ORIGINAL: Robrow
Hi, anyone have any experience?
Rob.
Rob.
I think the Rhino at 37 pounds thrust (engine weight 3.75 pounds) is perfect for the plane. Vertical is all you could ask for and plane weight will be in the 38 pound range with a blue box cockpit. Lose the cockpit, put in a TAMS pipe and you will get a weight around 35 pounds. Ehab hit the nail on the head ... this plane is in its element in constant speed IMAC type flight.
The plane flew ok on the Titan, but the loss in thrust compared to the Rhino is noticable. Gordon's P180 gave it a bit more top speed and more vertical from low speed (such as takeoff), but the added thrust wasn't always usable in maneuvers.
The oly at 50+ pounds and an engine weight of 6.25 pounds will hurt the plane. You will need considerable nose weight to offset the extra 2.5 pounds of engine weight, flight times will be shorter, and the landing gear which are the weak spot on this plane won't like all the xtra pounds. The intakes/pipe probably will not allow you to get to the full rated thrust. And you will very rarely have the stick at full throttle anyhow because you won't need it. Unless you are a pilot that absolutely gets off on top speed all the time, I would stay away from this engine/airframe combo.
