Skymaster F-86 Build
#182
RE: Skymaster F-86 Build
Thanks a lot Vincent. Did you instal an additional fuel tank or is it possible to fly a bit other 9 minutes with the tanks from the kit?
#187
Vincent,
Your total weight is amazing. I weighed everything including radio equipment and other components, before putting the plane together, as it came out the box BUT without my turbine, batteries and drop tanks I am at your weight.
I estimate my F-86 to end up very similar to my SM T-33, which is 21.5kg (47.5 lbs), even perhaps slightly more.
Cheers,
Jan
Cheers,
Jan
George and Vincent,
My apologies, yes you are correct I am referring to the big SM F-86.
Cheers,
Jan
