Jitters with Y connector 8411's
My Feedback: (164)
CA
Hi Guy's I am getting the jitters on the side with the reverser when it comes back to center. I am a point of just getting the servo reversed. But I just wanted to know if anyone else has experienced this on digital servo's.
Thanks in advance, Dave R
My Feedback: (8)
Dave, have you tried the servos with a standard y harness yet. If you have did they jitter at all when they returned to center. If not my guess is that little in-line servo reverser.
I personaly don't use them at all and have seen to many problems other guy's have had with using them. Do yourselrf a favor and get a reversed servo.
John Redman
Team BVM, Jet Cat USA
John Redman
My Feedback: (164)
CA
Reverser
Hi John:
You are right. I need to just go with the reversed servo. I was just wondering what would cause it to do that. It does not happen with standered servo's, but why the digital? Thanks John,
Dave R
Dave R
David,
Those servos aren't hard to reverse yourself. I was scared to do it because I paid so much for it, but it worked fine. The biggest problem is that gooey stuff in there. I cut through it with a clean blade, and did the standard reversing procedure. Try it?
Re: Reverser
Originally posted by Whodaman
Hi John:
Hi John:
Gordon
My Feedback: (61)
8411 chatter
When I first set up my AD F-16 elevons the 8411`s did not chatter until I set the elevon mix on the tx. When you touch them or put a load on the stab it stops. Kind of creepy but have many flights on them that way with no troubles. I even sent them back to Horizon for a check up and they did the same when they came back.
Vin...
Vin...
