 Jetronics Sequencer >
Jetronics Sequencer
Jetronics Sequencer
Old 03-28-2008 | 06:57 PM
maverick101's Avatar
My Feedback: (34)
Default Jetronics Sequencer
Hey All,
Im trying to program the sequencer for an F-86...{doors open, gear down, doors close/doors open, gear up, doors close}...If anyone has the manuel for it, and could send it to me....or could help with the programming, would be appreciated!!
Tommy
Old 03-28-2008 | 07:34 PM
Banned
My Feedback: (67)
Default RE: Jetronics Sequencer
Operation instructions
1. Adjusting switching point:
Turn on transmitter and receiver, set function switch to the “Gear OUT” position.
Set coding switch to position SP (Switching Point )
Push (-) button.
Set function switch to the “Gear IN” position.
Push (+) button.
Set coding switch to desired mode.
2. Adjusting gear valve servo end positions (G):
Gear switch at the transmitter to the “Gear OUT” position.
Coding switch to position G.
Push buttons + or - so, that the valve servo delivers the undercarriage.
Gear switch at the transmitter to the “Gear IN” position.
Push buttons + or - so, that the valve servo brings in the undercarriage.
Coding switch to wanted mode, or to next adjustment.
3. Adjusting Gear door servo (D1-D3):
Coding switch to position D1.
Push buttons + or - so, that the Gear door 1 servo opens.
Gear switch at transmitter to the “Gear IN” position.
Push buttons + or - so, that the Gear door 1 servo closes.
Repeating procedure for Gear door 2 and 3 with the coding switch positions D2 and D3.
4. Adjusting delay time between Gear doors and gear valve (between 1 - 3Sec)
Coding switch to TIME G.
One push on the buttons changes the delay time approx. 0.5 sec
By toggling the gear switch at the transmitter and pushing the +/- buttons find out the right delay time.
5. Adjusting delay time of Gear doors: (between 4 -13 Sec)
Coding switch to TIME D.
One push on the buttons changes the delay time approx. 1 sec
Note:
- By use of Jet-Tronics pneumatic valves it is recommended, to check the function of the circuit by using
normal servos, to understand more easily its operation.
- By using mode 3, D3 will be the nose gear door.
- If using new electronic components, always perform range check.
Old 03-28-2008 | 08:50 PM
My Feedback: (14)
Johnny, looks that I will have a lot of fun when my friend bring da Hawk to my place. Still waiting for Jason on S/C. Did you get yours from him?
Alex
