which kit is better?
need advice on which kit is better as far as quality,price and build,JHH A-4 or YELLOW AIRCRAFT A-4. it will be a ducted fan to fly off a local manicured grass runway. any help would be appreciated,thanks.
My Feedback: (57)
For your maiden I'd recommend you give it a try at Thunderbird field. Set it up, trim it, then take it to GSW.
Also, go for the Dynamax, OS.91, Weston pipe combo, works great! Sorry, that's if you decide on the Yellow, which I would.
Y/A is a geat build and flies really good.
David
David
