Stabilizer static balance?
My Feedback: (69)
How many of you guys are static balancing your all-flying stabilizers? I am preping an old X-Terminator, BVM/Viojett powered, and checked the stab for balance. The stabs are significantly tail heavy and will require about 4 ounces of lead (2 ounces in each stab leading edge) to static balance neutral. I'd probably need another 2 ounces in the nose to offset the weight if I can't take care of it with the battery pack.
So, do I need the additional 6 ounces of weight, or do I simply use a strong servo to prevent stab flutter? What would be the minimum servo power you would recommend if I go the "strong servo" route?
Tom
Tom
SM F-15 25ish pounds jr 8611a 100+ flights
SM F-18c x2 30ish pounds jr 8611a 2 flights, 30-40 flights
Extreme Jets F-18C 30 ish pounds Hitec 5955 11 flights
JL F-18C 30ish pounds JR 8611a 200 flights
SM F-4C 30ish pounds jr 8611a 40-50 flights
Century Jets F-4C 30ish pounds 8611a 40-50 flights
Do you need more info?
What's an x-terminator?
Raf
Raf
My Feedback: (10)
Hi Tom,
You might want to check with Chris Setting (the designer) on the set up, he posts on here pretty regularly.
On a (somewhat) related issue, I had an early Terminator and the stabilator pivot point was too far aft. I think I ended up moving it about 3/4 of an inch forward after an aero friend did some analysis.
The stabilator did not flutter, but the plane suffered a massive porpoising (about 2-3 cycles per second) at about 100 mph, very scary.
BTW I had a BVM fan and a 91R in mine, it was pretty fast, hard to land (slow down) I ended up adding a belly speed brake just like my BVM Viper.
Good luck,
Good luck,
My Feedback: (34)
ON, CANADA
Typically, full flying stabs are balanced by adding 80% of the weight that is needed to balance them level i.e. if you need 2 oz, add only 80% of 2 oz or 1.6oz.
Regards
Peter
Regards
Peter
ORIGINAL: TJK
Tom
Tom
