Byron F-16 Parts???
My Feedback: (43)
OH
Byron F-16 Parts???
In bad need of the following Byron parts, where is a good place to look / post for Byron parts?
Horizontal Stabilizer x 2
Vertical Stabilizer
Canopy
Byron OS engine fan mount
Die-cut wood formers
Vertical Stabilizer
Canopy
BC, CANADA
RE: Byron F-16 Parts???
Most of that can be made pretty easily.
Iron bay should be able to provide everything but the foam pieces. I don't think they ever got the foam injection system or molds from Byron. Either way - they cannot provide foam pieces, but you should be able to cut your own and sheet or glass them.
My Feedback: (43)
OH
Iron Bay is of no help[] Need the size info on what size to cut the foam parts. IF someone has a F-16 that could provide what size I need to cut the foam would be great[8D]
My Feedback: (10)
NE
did you get a responce from iron bay?? skyhawknut is right, iron bay can get you everything but the foam peices. it may take them a month to respond to you, but they will. not the best way to do business, but in your case you dont have much option. give it 3 weeks and if you dont get a responce try again...
My Feedback: (43)
OH
ORIGINAL: donniercjet
But I will keep trying.
If nothing else, they are only a 3hr drive away
Charles
My Feedback: (39)
PA
Charles,
I have a whole Byron F-16 from ducted fan days, hit on nose, one leading edge crunched, all there.
If you want , you can come get it, or I'll bring it to a meet down your way. We attended Columbus Jet meet last year, may go again this year. Check with me closer to the date. Meanwhile, I'll send you the stabs.
Dale
Dale
My Feedback: (43)
OH
ORIGINAL: S HARRIS
I have the tail section (with stabs and linkage) hanging around some where. It's yours for shipping cost only. Scott
Let me know the cost of shipping to 43102. Think I need to stock up on lots of extra parts
My Feedback: (43)
OH
I got a nose cone and collar
I am looking for the following yet.
Vertical Stabilizer
Canopy
Charles
Vertical Stabilizer
Canopy
Charles
ORIGINAL: Charles Thomas
Vertical Stabilizer
Canopy
Charles
Vertical Stabilizer
Canopy
Charles
I have a byron engine mount. it was fitted with the rossi 61 (might have been the .81, i've since learned) it thats the same as the OS one then your in luck....
I'd be in luck if anyone has the retract mounts for the F-16 they no longer require....
thanks
dave
CO
http://www.dbalsa.com/
Dynamic Balsa lists foam wings for the F-16 looking under foam wings,letter f, They lsit the wings, stabs and fin.
Rod
Rod
