Amplifier for Jettronics Valves (for 2.4)
My Feedback: (24)
I have read that the older Jettronics Door Sequencer and Brake Valves have a problem recieving the signal (from the receiver) on 2.4 systems. I guess a Matchbox or PowerBox can be utilized to rectify the problem .... but I heard that Jettronics (or some other company) was going to come out with a fix .... some sort of an in-line amp/booster. Wondering if it is available yet ? Thanks. Bob
JR makes an amplified Y harness, dunno if it will solve the issue or not, they are not recommended for use on digital servos though FWIW.
Hi Bob!
The signal amplifiers from Jettronic, Powerbox or Emcotec are available. They are only needed on Futaba recievers, due to the low signal voltage. But I would try it first, because they are not always neccessary.
BR,
David
BR,
David
