"ask"airfoil f-16
RE: "ask"airfoil f-16
Ok, found it!!
http://www.pdas.com/sections6a.htm#64A204
Got a nice table so you can plot the foil useing the percent of cord to heights above and below the referance line!
That web site above dose not have thw McD D F-16 listed! I check it first as it is on of the eirst places I go for foil data. I could send you the outline in PDF form if that will Help!
So you agree then, about the airfoil anyway. PLEASE do'nt shoot the messanger!
http://www.aerospaceweb.org/aircraft/fighter/f16/
My Feedback: (24)
Give me some specifics on the wing and I can generate the planform and templates for you if thats what you need?....
Need span, root and tip cord, LE sweep. N64204 airfoil below.
TO lov2flyrc
I MADE MOLD F-16 FROM WOOD
AND I 'M NOT PROFESSIONAL
Length :1878 MM & WINGSPAN : 1300 MM
HALFSPAN : 450 MM
ROOT : 509 MM
TIP CHORD : 167 MM
SWEEP : I DONT KNOW
PLEASE IF ANY THING IS WRONG TELL ME
THANKS FOR EVERY ONE
HALFSPAN : 450 MM
ROOT : 509 MM
TIP CHORD : 167 MM
SWEEP : I DONT KNOW
My Feedback: (24)
ORIGINAL: poxy
TO lov2flyrc
HALFSPAN : 450 MM
ROOT : 509 MM
TIP CHORD : 167 MM
SWEEP : I DONT KNOW
TO lov2flyrc
HALFSPAN : 450 MM
ROOT : 509 MM
TIP CHORD : 167 MM
SWEEP : I DONT KNOW
Need to know the sweep angle, this is the offset measurement from the root LE to the tip LE. Provide me this and I can mock up the wing. How do you plan to make them? Wood, foam, composite? Need to know how you want the templates supplied.
Found the best 3-view image I could and brought it into AutoCAD and rubber sheeted it the specified Length and span and came up with the following!
Inboard foil: length = 11’-10 ½”
Outboard foil length = 3’ - 6”
Wing panel length = 10’-10 ½”
Looking at all the 3-view general the following thoughts:
The top of wing is flat, dihedral comes from the raise in the bottom of the wing.
LE is perpendicular the CL of A/C, which translated into a TE setback at tip of 8’- 4 ½” or 38°.
Looking at the image it looks like there is washout as the LE CL runs towards the bottom of the tip rib, I am thinking till the foil aft top is basically straight with the A/C CL, giving a sweep angle of 3°.
If I did the math right POXY's scale down is a multiplier of 0.137600806!
Your numbers seem to be scaled OK, and varied only slightly from mine. I believe this is due to the different images we use to generate them. Your scale is a little strange 1:7.268307692 (31' span x12 = 372", 372" x 25.4 = 9448.8 mm, 9448.8 / 1300 = 7.268307692 your scaled number for span)
Excuse me for butting in guys, but whilst that may be the correct wing section for the root of the F-16, surely it is not correct for the tip. The f-16 tip appears to have a lot more camber as well as washout. Or am I seeing things?
Regards,
John
Regards,
John
John
The 64A204 is listed in more then one set of offical specs. as both root and tip foils.
poxy
E-16 wing span is 31' x 12 = 372" of span, take this x 25.4 to get the 9448.8 mm real world wing span. Divid that by your scaled wing span of 1300 = 7.26807692. This gives you your scale factor of 1:7.2607692, or multiply the real world dimension by 0.137583608 to get a scaled length of your item in (mm).
poxy
