Nose Wheel Steering Gyro Location
I'm considering putting a gyro on my nose wheel steering and I'm not convinced that it has to be at the CG as you would with a flight control gyro. I drew some diagrams to determine if location made a difference and I see no location that is better than another. If the nose wanders off heading, the gyro is still feeling rotation about its axis and should try to compensate back to the correct heading. Am I missing something?
RE: Nose Wheel Steering Gyro Location
For gyros commonly used in R/C-aircraft and helis it does not matter where along the length axis of the aircraft it is located. You can position the gyro where it is convenient. Solid state gyros are not sensitive to translational motion, only rotation. When the aircraft is turning all parts of the aircraft rotate at the same rate.
ORIGINAL: drdoom
Centerline of rotation, the gyro needs to turn, NOT Swing.
