 use it or not ? >
use it or not ?
use it or not ?
Old 05-21-2008 | 02:59 PM
My Feedback: (18)
Default use it or not ?
i am looking for a practical experience answer here , and i also put the question on the eng forum , but need a sooner than later answer.
i have a simjet 2300aes w/ a 2002-d2 fadec ecu and a propane sol. with an adj needle valve built into it that works great .
but heres my problem in the current model there is no where to put the sol that allows me access to adj needle if needed , so i want to use sol externally and unhook from ecu after start up and i am wondering if ecu will recognize this and go into a immediate shut down ?
thanks for the info,
Old 05-21-2008 | 05:53 PM
Gary Arthur's Avatar
My Feedback: (29)
Default RE: use it or not ?
I have a Simjet 2300 and do not use the propane valve at all. I hook up the propane and regulate it externally. Once the engine ramps up on kero I unhook the propane and fly. No need to use the supplied propane valve and regulator.
Old 05-21-2008 | 06:32 PM
FalconWings's Avatar
My Feedback: (57)
On my Simjet 1200 I did away with the propane solenoid. Just like Gary I had a regulator hooked up to the Coleman can directly.
David
Old 05-21-2008 | 09:15 PM
Wayne22's Avatar
Me too.... but on a wren.. works fabulous. Just be sure to use a check valve on the end of the propane line....
Old 05-21-2008 | 09:25 PM
seanreit's Avatar
My Feedback: (60)
ORIGINAL: Wayne22
Did you find out the hard way too?? Replacing "THAT" festo fitting is a pain.. [:@]
Old 05-21-2008 | 11:15 PM
Wayne22's Avatar
No, just want to keep the hot air inside the turbine.....
