Jet Legend assembly Hiccup
My Feedback: (39)
PA
Hi Guys,
Assembling my JL F-15, diccovered the front retract cylinder is leaking badly at the shaft seal. Do you have any advice the make it stop ? PLEASE make it STOP !! I've contacted CamLex, hopefully for a speedy replacement.
Dale
Dale
My Feedback: (28)
RE: Jet Legend assembly Hiccup
Hi Dale.
Disassemble the entire unit. Wipe all the grease off and inspect the shaft (for burrs) and O ring for tears. Replace the o rings if needed and polish any burrs down. Then reassemble with your favorite lubricant. I use synthetic wheel bearing grease on every retract I own. Completely disassembling, inspecting and reassembling is part of my build routine. I just have to look inside. I like to reassemble with locktite. More than once I have found dry o rings or metal debris inside. I'll see ya this weekend.
Dale
Contact the factory, they will get right back to you. Oh wait did you pay for this already. Ha ha ha ha ha ha ha ha ha, ya they will get right back to you.
Good Luck!!!
Good Luck!!!
My Feedback: (39)
PA
Camlex got back and said to try BVM o-ring stuff. If that doesn't work, send them the entire retract and they will get JL to replace. ( that sounds lengthy ), so I will oder some stuff on Tuesday, and give it a try.
Dom,
I have witnessed Captain Crackers sliding 'er in , several times, I think he just likes to show off . I prefer the boring old wheels landing. In fact, the more boring the better.
Dom,
