SKYMASTER HAWK CONSTRUCTION WARNING !!
My Feedback: (28)
As I was working to mount the horizontal stab servo tray I was trying to tighten the blind nuts attached to the servo tray mount rails the rear mounting rail popped loose from the former. There was little to no glue holding the rails to the formers. The rails are "keyed" into two formers under the vertical stab to form a mounting platform for the servo tray. It looked as if thin CA or a very thin layer of epoxy was used to glue the rails in place. To correct mine I reglued them and placed triangle stock on the top side (towards the vert stab) to give more gluing area. It would make a bad day if your servo tray came loose too! Glad I found it now.
Hi Tom
Thank you for your reminder.We checked our kits ready made here and found this area is well glued.So,this problem should be an isolated issue.However,our quality control dept. will reinforce the inspection on the mounting rail area as you indicated.
Best regards
John
Skymaster Jets
Best regards
John
Skymaster Jets
My Feedback: (28)
John,
I would recommend for you that the servo tray mounting rails be installed and reinforced prior to the fuselage formers being installed into the fuselage. Only then can you be assured that the glue joint for the servo tray mounting rails are secure.
