 tailor made water decals >
Old 06-15-2008 | 01:27 PM
Default tailor made water decals
Just recieved some decals from tailor made , the one that are water slide . I am putting them on a plane that is finished and do not want to clear coat. Is there a way to seal the decals after they are dry. I try to wax but the print comes off the decal. Also I tried a clear coat enamel with a small paint brush , that didnt work either. It is a high gloss sport plane that is painted in the mold so anything like trying to paint over just the decal will show up like a sore thumb?? The reason now that I dont want to clear coat is cause its to late, I was to anctious when I got them and didnt think. To late to scotchbrite the fuse cause the decals are on the plane already. I just couldnt wait , just started putting those little suckers on and couldnt stop It was like I was posessed. Now Im scared to even clean the plane.
Old 06-15-2008 | 01:46 PM
tp777fo's Avatar
My Feedback: (28)
Default RE: tailor made water decals
I would just mask off the area around the decals then use some rattle can auto clear with a very light dust coat, let it get sticky then put another one until you get a gloss
Old 06-15-2008 | 02:38 PM
Redline7000's Avatar
Plastic modelers use lacquer overcoats to seal decals. I personally use Model Masters Gloss Coat. Not as heavy as an automotive clear coat. Try it on a small surface and see if you like the results.
Old 06-15-2008 | 07:48 PM
FalconWings's Avatar
My Feedback: (57)
You have to seal them with laquer and then clear them, otherwise the edge will show.
