Reload this Page >
Turboprop smoke injectors
Old 06-29-2008, 03:08 PM
P38J
My Feedback: (14)
P38J's Avatar
Default Turboprop smoke injectors
I'm getting ready to install smoke on a Wren turboprop, I'm trying to find out how to install the smoke injector. Do you just drill a hole into the exhaust stack an insert the standard type nozzle or install some kind of threaded fitting.
Old 06-29-2008, 05:44 PM
Wren Turbines USA
My Feedback: (39)
Default RE: Turboprop smoke injectors
Wayne,
Call me Monday...........
260-724-8936
Old 06-29-2008, 05:54 PM
P38J
My Feedback: (14)
P38J's Avatar
Thanks Ron, will do.
Old 06-29-2008, 09:07 PM
TommyWatson
Roger at Wren did mine before I got the engine. He put two (looks like about 2.5mm) SS pipes into the rear of the exhaust stacks about 2" away from the centre. I have not used it yet so I don't know how effective it is. The two pipes go back to a brass "T" piece then back to the pump.
Regards
Old 07-09-2008, 12:05 AM
P38J
My Feedback: (14)
P38J's Avatar
here is a pic of the injector that I came up with, it worked very well.
ID:	986797   Click image for larger version
Old 07-09-2008, 12:51 AM
747drvr
747drvr's Avatar
Hi Wayne,
Are you installing 1 or 2 and where are you putting it/them . I have a 44TP that I would like to add smoke to.
Marc
Old 07-09-2008, 02:49 AM
P38J
My Feedback: (14)
P38J's Avatar
I installed one injector as close to the center as possible and we adjusted the direction of the oil spray until we got even smoke from both exhaust stacks.
here is a video of the first flight with the smoke installed after the flight we adjusted the injector.
http://www.rcuvideos.com/item/W98CY2XZF6K0YY6J
