 Fadec ECU Question? >
Fadec ECU Question?
Fadec ECU Question?
Old 06-30-2008 | 09:27 PM
Default Fadec ECU Question?
I recently converted a Wren 54 to a Fadec autostart ECU. Can you prime the fuel pump with an autostart ECU? If so, how do you do it? I was able to prime my manual start ECU by moving the stick to full throttle.
Thanks for any help.
Hal
Old 06-30-2008 | 09:33 PM
seanreit's Avatar
My Feedback: (60)
Default RE: Fadec ECU Question?
Depending on the version, there is now a menu item for pump, I think it's in the run menu, but not sure, just go through the items. Let me know what you find.
Old 06-30-2008 | 09:39 PM
My Feedback: (12)
Place the trim down and raise the thottle stick all the way up and wat a few seconds, the pump will prime.
This is what my SS manual says.
Old 06-30-2008 | 09:40 PM
My Feedback: (12)
if its a Jet Central engine its in the menu.
Old 07-01-2008 | 01:27 AM
highhorse's Avatar
Agree with Freakster, SS manual says trim full down or activate the throttle cut, whichever is appropriate to your setup, and open throttle to full for 5 seconds to start the pump.
Old 07-02-2008 | 10:00 AM
Thanks for the help. Mine must be an older version because it is not in the menu. I purchased the ECU about a month ago. Could I update the software so it would be in the menu?
Hal
Old 07-02-2008 | 10:02 AM
seanreit's Avatar
My Feedback: (60)
Not many can do that from home. Follow post 3 above, and if that does not work, push the up arrow once and try post 3 again.
