what equipment / tools
FL
hey all...
i am new to jets...have a mini boomerang on its way....
what should i buy as useful tools/equip?
also what is everyone using for air compressor and blower?
thanks
larry
thanks
larry
My Feedback: (43)
NM
If you are installing brakes and retracts you will need a small air compressor to fill the air tank. You can get one most anywhere, but Bagostix sells one that is really great. Also a fuel can and pump for the kero, your gas one will work if you have one. Some powermax or propane for starting if your motor is not kero start, kerosene and turbine oil, guess that about covers it. You really take less to the field for a jet than for a glow prop plane. hope that helps. and building is just like any other arf except you may want to heat treat the hatch. I put alum tape on the bottom of the stab and on the inside of the hatch. Lowes home improvement, plumbers tape. Bob
Not always used but a very useful "tool" for turbine jet fliers is a good fire extinguisher... always have one handy while operating a turbine!
Enrique
Enrique
ORIGINAL: SGT.SHAGGY
I dont think that you can buy Halon ext. anymore, but if you do its going to cost you for the refil and for the turbine repair.
