Tamjets 1:12 scale, Jetcat P-60SE combo and flight video
Hi guys,
Just let you guys know the container left china few days ago.
In the container there is 1:12 scale F-16 turbine version.
Here is the Tiger Meet scheme I just flew today with E-power. The the turbine version had rudder.
We only had dozen of this Tiger Meet color scheme in stock.
Thunder Bird, Edward and General dynamic also available in this shipment.
All this kit final ARF'S assembly here in the US for highest quality control.
We start taking pre-order now. Price starting $599 for ARF kit. $699 for Tiger Meet scheme.
Retract and wheels/brake $299.95
Tailpipe, UAT kit and Sullivance tanks $220
More information will post soon or you can call us for more detail.
Here is the video flew today with E-power.
http://www.rcuvideos.com/item/FHGXTJXB7FMSR5ZS
Turbine version video
http://www.rcuvideos.com/video/Tamje...rbine-Tiger-Me
MA
RE: Tamjets 1:12 scale F-16 turbine version is almost here
Hey Tam....that EDF looks the perfect size for a 44-Gold....of which I have one ! Any plans for an ARF-turbine version?
Ray
Ray
Ray,
We had about 50 of this kit availble with rudder for turbine use. The wing alignment and some other former are done here for better quality control.
In the pass all my ARF are assemble in china. But due to poor quality from china labor. We bring works back here to had it done right. It cost little more.
But every kit left my shop will end up with a happy customer.
P.S. FF Bob.
You are behide James S.
He order his a week before I even announced.
P.S. FF Bob.
Kevin,
We only had enough this kit with rudder for turbine.
So that option not available. You could made rudder out from that kit. We did it with our proto type.
Vin,
Tam is flying the prototype with a P-60. So I guess that a Artes Bee would work too. I think that the '44 gold would be the best combination due to the light weight and low fuel burn....................
Tailwinds,
John
Tailwinds,
John
ORIGINAL: gooseF22
Tam,
are there any remaining that are not spoken for?
Tam,
Tiger Meet are counting down.
Get your order within few days before sold out.
CA
The prototype is being flown with a P-60 with more than enough power. It would fly great with a 44 and would still have close to a 1 to 1 thrust ratio. This is truly a recession proof jet...3 flights per gallon of kero, unlimited vertical, easy to transport and flies great! Here is the link to the original prototype thread:
http://www.rcuniverse.com/forum/m_70...tm.htm#7056388
The flights yesterday were a blast on the 8S setup. Although you can add cells and blast verticals, the 8S combo was great! Plenty of power and lightweight. Remember, less cells is less money for batteries!
All new are the wheels and brakes. Regardless of psi (60lbs or 110lbs) these brakes work the same. They won't lock up the wheels and are just a great design. Here is the link to the new brakes and wheels.
http://www.rcuniverse.com/forum/m_75...6%2CP60/tm.htm
I can't decide which one I like more, the P60 or electric! Turbine sounds cool and justs sips the kero...but electric is just so easy and with the price of 8S packs, you can economically own 3 packs and fly all day long.
Russ
Russ
The 3 flights yesterday only took 2100mAh average for 3 mins.
So the pack we got onboard good for 4.5min. Since it so light. We can use 4450mAh. That is solid 6 mins flight time.
What else can you ask for fun and affordable jet during the bad time.
MA
Well....where have I been ?
OK, about $1100/1200 'complete'....not bad, Tam! Is that ARF for a 44-Gold...and what's the weight of that combo w/ UAT full? Work needed: anything major beyond systems installs? Is the gear grass capable? Love to hear of the first Gold flights.....Tx!
Ray
Ray
ORIGINAL: Ray Davis
Ray
Ray
Ray,
The plane pretty easy to assemble. Normal it took us 20-25 hrs to finish RTF. That including do the gear doors. If not doing the gear door. You can do it in 15-18 hrs.
Sorry guys,
I can't get around to put up online pre-order page. Trying get things done in the shop before leaving for LA Jet tomorrow morning.
I promise will get it done on monday for pre-order.
I just update my online store to pre-order this F-16 ARF's kit.
http://www.tamjets.com/original/prod...roducts_id=429
Just quick update.
The container are at the port. Our agent getting to clear custom and should be delivery our shop end the week.
ORIGINAL: AFTERBURNER1
Flew this bad boy at LA jets.... GREAT FLYING JET!!!
ORIGINAL: seflyer
You gonna leave that big toy box outside all alone tonight?[:-] just kidding. Kevin
After I go maiden flight the Spark. I drag Ray and Russ come back to the shop unload.
