TBM Shock Jet
#1127
NC
RE: TBM Shock Jet
Thanks for the info. I will have to decide if it will be worth it to do all of that. I'm thinking of getting a new airframe, either a Boomerang Sprint, or a Modelbau Tornado. Either will take the Falcon and a larger tank. Decisions, decisions.
#1128
NC
RE: TBM Shock Jet
ORIGINAL: Tip22v
Toprudder, what field are you flying your Shokjet at? Just curious as I moved out here to the west coast 6 years ago from Raleigh.
Tom
Tom
You have my sympathies with the shift to the far left.
#1130
My Feedback: (106)
RE: TBM Shock Jet
YeaI was real happy with my shock until I flew the one I set-up for Bob and now it's got me thinking about putting my K-80 in it and the 14# turbine in my Nano. Thanks Bob. Now I may go ahead and get you to order two of those tanks. Ha. Ha. By the way, you can lay one up in a week-end for about 30 bucks. After you make the plug that is. LoL. Bob, you make the plug and I'll make the mold.
#1138
My Feedback: (17)
MS
RE: TBM Shock Jet
I have been flying a P-80 in my ShockJet for about a year now. I have an 80 oz. fuel tank that I got from Ali's Jet Central that gives me about 10-12 minutes depending on throttle management. Plenty of power but I have to resist the temptation to fly much past half throttle.
#1139
My Feedback: (8)
RE: TBM Shock Jet
With my Rabbit, I use full power often but not for long. This is easy with the newer, faster spooling turbines. With the SuperBee, I firewalled it at take off and pretty much left it there until just before lowering the flaps for landing. Not nearly as much fun as with the Rabbit but simpler when I was new to jets.
#1141
My Feedback: (8)
RE: TBM Shock Jet
Tip22v has a k80 in his. Having flown it, I can tell you that it's VERY hard to tell from the Rabbit once it's running. His k80 is kero-start and takes longer to start and get ready. Once running, it's a great combo. The k80's greater weight requires more ballast in the nose, but the airplane doesn't seem to mind and I can't tell, either. Hope this helps.
#1144
My Feedback: (106)
RE: TBM Shock Jet
ORIGINAL: gjhinshaw
HEY Hooker!!! I am still flying mine also!!! HEHE.. I have over 300 flights on it!! The Falcon is doing good in it! I will always have one too!!!!
#1145
RE: TBM Shock Jet
ORIGINAL: rcguy59
Thx,
Steve
#1146
My Feedback: (8)
RE: TBM Shock Jet
The thrust output of the SuperBee is low enough to allow the airplane to be flown around at full throttle as long as you don't bang the sticks around. The Bee spools notably slower than the Rabbit, making throttle management more difficult at first. The Rabbit has enough thrust to ensure instant destruction in the event you pull too hard, too fast. Going over 150 mph with an all-wood Chinese ARF means being careful not to do anything silly, as you won't get a second chance. Excess thrust in a Shokjet is best used in the vertical and not for speed. (IMHO)
