Reload this Page >
TBM Shock Jet
TBM Shock Jet
Old 06-14-2012, 06:28 PM
  #1301
blainer48
My Feedback: (30)
Default RE: TBM Shock Jet
I have a P-70 in mine and you will love that combo.  I don't have the TBM tank in mine because I have the Jet-Tech tank but either way you will love it.  Very easy flier and you won't have any issues.  Good luck with the maiden and with your waiver.  Keep up posted on how you do as well as the plane.
Jason
Old 06-14-2012, 06:31 PM
  #1302
blainer48
My Feedback: (30)
The one thing I noticed is you battery is back by the ECU. I placed all 3 batteries as far forward as possible and that helped with the balance. In fact, after I added the second 2600mAh Li-Ion in the nose for the receiver, it balanced with no additional weight needed. Just an FYI on maybe shifting your batteries in the nose to help. Also, Idid not have to shim anything on the motor and Idid not touch the trims and still haven't. Also, watch how much down elevator you mix with the flaps. I added what TBM sort of recommends as a starting point and it was too much for me. The nose pitched down pretty good but I was still able to easily manage it with the stick. So I dailed out a bit and now for full flaps I am almost using what they recommend for half flaps and no elevator mixed with half flaps. Now, that is my set up and everyone else is different just letting you know what I am seeing with mine and the P-70 combo. Hope it helps.
Jason
Old 06-16-2012, 06:23 PM
  #1303
bw5493
My Feedback: (36)
The SJ flies!! today we not only maidened the SJ, I was able to become Idaho's 8th Turbine waiver holder!! Sweet flying combo with the P70. Not really unlimited vertical, and it's not the fastest jet at the rally, but it sure flies nice.
Old 06-18-2012, 03:55 PM
  #1304
blainer48
My Feedback: (30)
Congrats on the waiver and the successful flight flight of what I hope are many. Welcome to jets! Now your hooked.
Jason
Old 06-22-2012, 08:28 PM
  #1305
bw5493
My Feedback: (36)
Here I am starting my first flight without the training wheels!
Old 07-14-2012, 01:26 PM
  #1306
diegocolonnello
diegocolonnello's Avatar
Hello pople, here i am with my SJ in the Valencia Jet Blast 2012 in Venezuela....
Turbine is a RAM 750 Full auto Kero Start using Xicoy Fadec ECU
Radio is a Futaba 12z 2.4 fasst....
Servos are Power HD from TBM....
Smoke coming soon.
Old 07-27-2012, 11:30 AM
  #1307
BILLYDSRC
BILLYDSRC's Avatar
Hi All, Just want to share some pics with you on this build. Im building this for a great friend of mine and i have to stuff in this older turbine in her
I started on it lastnight @ 9:30pm and worked on it till 12:30. Back at it this am. and Got the mouting plates made and ready to start putting servos in!!!
I will post more as i go.. Thanks Billy D
ID:	1786524   Click image for larger version
ID:	1786525   Click image for larger version
ID:	1786526   Click image for larger version
ID:	1786527   Click image for larger version
ID:	1786528   Click image for larger version
ID:	1786529   Click image for larger version
ID:	1786530   Click image for larger version
ID:	1786532   Click image for larger version
ID:	1786533   Click image for larger version
ID:	1786534   Click image for larger version
Old 07-27-2012, 11:31 AM
  #1308
BILLYDSRC
BILLYDSRC's Avatar
More!!!
ID:	1786536   Click image for larger version
ID:	1786537   Click image for larger version
ID:	1786538   Click image for larger version
ID:	1786539   Click image for larger version
Old 07-27-2012, 12:55 PM
  #1309
BILLYDSRC
BILLYDSRC's Avatar
Ok I got all the shoe horns in the town to get it to fit!!! ...LOL...It is a Behotec Turbine 66.. It puts out around 13lb. Should fly this Cub great
ID:	1786580   Click image for larger version
ID:	1786581   Click image for larger version
ID:	1786582   Click image for larger version
ID:	1786583   Click image for larger version
ID:	1786584   Click image for larger version
Old 07-27-2012, 11:09 PM
  #1310
BILLYDSRC
BILLYDSRC's Avatar
Ok, Got a ton more done tonight!! Lot more then you can see in the pics. Like running all the wiring and got the RX all wired up tooWill finsh up the wings tomorrow.
ID:	1786676   Click image for larger version
ID:	1786677   Click image for larger version
ID:	1786678   Click image for larger version
ID:	1786679   Click image for larger version
ID:	1786680   Click image for larger version
ID:	1786681   Click image for larger version
Old 07-28-2012, 03:00 PM
  #1311
flyboy61045
My Feedback: (10)
flyboy61045's Avatar
Looking good Billy
Old 07-28-2012, 07:33 PM
  #1312
BILLYDSRC
BILLYDSRC's Avatar
John, Check out how i got the Tam brakes to work
ORIGINAL: flyboy61045
Looking good Billy
ID:	1787156   Click image for larger version
ID:	1787157   Click image for larger version
ID:	1787158   Click image for larger version
ID:	1787159   Click image for larger version
ID:	1787160   Click image for larger version
ID:	1787161   Click image for larger version
Old 07-29-2012, 03:23 AM
  #1313
flyboy61045
My Feedback: (10)
Nice work Billy,do you ever sleep?
Old 07-31-2012, 11:54 AM
  #1314
jefff
My Feedback: (8)
Looking good Billy D. Can't wait to see more. Time is getting shorter.
Old 07-31-2012, 11:58 AM
  #1315
jefff
My Feedback: (8)
Looking good Billy D. Can't wait to see more. Time ius getting shorter.
Old 07-31-2012, 02:31 PM
  #1316
flyboy61045
My Feedback: (10)
2 Posts you must be partying again
Old 08-01-2012, 01:33 PM
  #1317
BILLYDSRC
BILLYDSRC's Avatar
Jeff when are you coming home?? Your the only one on earth that can start this old ***** turbine
ps have just one more and we can see 3 or 4 post of the same thing.LOL
Old 08-01-2012, 06:39 PM
  #1318
jefff
My Feedback: (8)
One dead Jack. I just started #2. Very little wind for the kites. See you Sunday. Aeros has a Fly-in Sunday. Will you have it ready to fly? Then we only have to program and plum it
Old 08-01-2012, 07:05 PM
  #1319
flyboy61045
My Feedback: (10)
Jeff you need this kind of plane
http://www.youtube.com/watch?v=pIoS_yqodBU
Old 08-02-2012, 08:56 AM
  #1320
BILLYDSRC
BILLYDSRC's Avatar
Sorry John But we went camping all week so it looks like i will be up all night friday getting her done
Old 08-02-2012, 09:46 AM
  #1321
flyboy61045
My Feedback: (10)
It was a nice week for camping,your still faster at building than I am now.
Old 08-05-2012, 10:46 PM
  #1322
BILLYDSRC
BILLYDSRC's Avatar
Working day 3 on it. Just have to plum it now. Here are some more pics. Thanks Billy D
ID:	1789574   Click image for larger version
ID:	1789575   Click image for larger version
ID:	1789576   Click image for larger version
ID:	1789577   Click image for larger version
ID:	1789578   Click image for larger version
ID:	1789579   Click image for larger version
ID:	1789580   Click image for larger version
Old 08-06-2012, 02:35 AM
  #1323
jefff
My Feedback: (8)
Looks good Billy D. You must of stayed up late last night. The plumer will be there in the morning.
Old 08-06-2012, 10:31 PM
  #1324
BILLYDSRC
BILLYDSRC's Avatar
She is ready to GO!!!! Maiden tomorrow AM or when i get up
ID:	1789920   Click image for larger version
ID:	1789921   Click image for larger version
ID:	1789922   Click image for larger version
ID:	1789923   Click image for larger version
ID:	1789924   Click image for larger version
ID:	1789925   Click image for larger version
Old 08-07-2012, 03:33 AM
  #1325
flyboy61045
My Feedback: (10)
Great work Bill see you at the field
