thrust P-160SX
Banned
My Feedback: (88)
ORIGINAL: A MAY
sence the titans are out will there be service available for these turbines when things go bad. i just got a used one...
Arden
Arden
Guys we have used two of these engines for more than two months now.
http://www.rcuniverse.com/forum/m_76...tm.htm#7620423
Here are my findings:
Cons:
No auto cooldown feature,
Acceleration not faster than the 160SE/Titan
Not 100% reliable ( I have had two engine failures already, my engine has a fuel leak, so it is back to Jetcat factory for evaluation
Starting plug not interchangeable by the user
Only slightly more thrust than the 160 SE
Pros:
Very smooth Kero start ( much cooler than the 160SE )
Amazing sound
At this point I don't believe that the extra money is worth paying for so little advantages.
The G-booster 160+ is a much better option at this stage.
I cannot compare with the Jet Central products since I have never tried them.
Cons:
)Starting plug not interchangeable by the user
Pros:
Amazing sound
#32
furloughed ual
I check 2 Titan thrust yesterday... for my surprise all the 2 didn´t push 34lbs as JETCAT say.... we compare 2 titan, 1 P120, 1 JETCENTRAL EAGLE, 1 Merlin in the same test table with didital scale..... all in the same altitude.. we notice that all the turbines lost 1 lbs because we are 2500 feet high..
First and Second TITAN 29lbs
P120 - 27lbs
Eagle - 29lbs
Merlin - 36lbs
In my opinion JETCAT Titan doesn´t have the power that JETCAT sell... anyone has other numbers??
P120 - 27lbs
Eagle - 29lbs
Merlin - 36lbs
#33
interesting #'s.......I really have no experience with using a quaility setup to check thrust....the reason for my crude comparison was to see which of our 2 turbines (Jet Cat/Artes) pushed harder.....the actual thrust numbers were not accurate....the difference in thrust was....
#36
It will be interesting if someaone could compare the new 160SX with the Titan...
JETCAT stop to sell the TITAN, maybe now with the 160SX they are "fixing" the things... selling a turbine with 36lbs that "has" 36lbs..
#37
I really miss the unbelievable relaibility of my non-SE titans.
I've only had unexplained flame outs with my SE's. My old P-120 keeps on truckin' as well.
Not to say that the reliability of the SE's is NOT top notch, but I think that the extra demands placed on the fuel and electrical systems means that more attention needs to be placed on those areas when installing an SE in your model.
I would guess that the P160SX will be similar. I'm happy right now with my SE's, so I'm gonna wait.
I want a minimum 55# turbine for "real" scale jet flying....
Raf
Raf
