Spektrum problem ???
Hello Friends:
I bought a Spektrum receiver and modul for my JR10X, but no run If I take out the external receiver. It is neccesary the external receiver for run or not ?
Thanks in advance.
__________________________________________________
http://cmjets.blogspot.com/
Thanks in advance.
The system is designed so that you must have the external ( Satellite ) Antenna plugged in when you switch on for it to work.
If the Satellite fails or come unplugged once the system is switch on and bound then the main receiver will cary on working without the satellite. Great idea/system if you ask me.
Hope this helps?
Regards Al
Hope this helps?
Regards Al
Hello Friends:
Tomorrow in the mornig I will probe it. I will swich on with the satellite plug in and them I will take out for see if run same.
I will tell you anything.
Many thanks.
Carlos.
And don´t forget visit my Blog:
Many thanks.
Carlos.
FL
Be careful man, I can't speak for the 9000 but I was flying with a AR6200 at one time and I was getting hits. I was able to land and discover that the remote rx died. In my opinion, the AR6200 or the AR7000 without the remote rx is a parkflyer.
Doug.
Doug.
