help, My Spectrun wont bind
my 7000 wont bind in my new jet. it\\both rx's just flashe once and just sets there when I power up with the bind plug inserted in the charge port.......................
My Feedback: (25)
Had the same problem in trying to bind my 9000. It would do the same thing you describe when trying to bind using the charge port. I had to insert the bind plug into the battery/bind port of the receiver and use another port for the receiver battery to power up.
That is exactly what I do. I run 2 batts anyways. So I simply take the battery out of the batt port and leave the other battery in one of the Aux channels.
Also be sure you are not in the data port......that won't work either.
