JR DS168 Thin Wing servo installation in ELEVATOR????
My Feedback: (194)
Hello:
Would like to know your opinion and comments if a JR DS168 will work on the elevators of an F86 from Fei Bao???? Plane will weight 24 pounds. I will be installing a 23 Lbs. thrust turbine...
It is just that those servos will fit perfectly... but I have my doubts in regards to torque... Any technical advice would be greatly appreciated.
thanks.
thanks.
My Feedback: (12)
I have 9411's in my f-86, I used them because of there low profile to give more clearance from the pipe. they are 95 oz at 6 volts. I think they are more than adequate as the elevators are very small and it has a long tail moment. Kevin
My Feedback: (44)
Even if the torque seems to be enough for the application the problem with the thin wing servos is the small gear train is prone to stripping, I would not recommend this servo for an elevator application on this size of jet.
