Rabbit Tail Pipe
QC, CANADA
Hello,
I'm working on a tailpipe for my Rabbit, I only need it to be 10.5 inch length, but I don't know which diameter is correct ?
Any suggestion ?
Also, if thing aren't going find (let say perfectly... ;-)) I may buy one, but I don't know where, any suggestion ?
Any suggestion ?
QC, CANADA
Per Eric Clapp, here is his answer :
> Ideal turbine pipe size as follows:
> 60mm is the minimum
> 75mm is the maximum
> We have tested and are very satisfied with these measurements. Feel free to post on RCU which will benefit us as well as you.
Thanks to all,
Robin
> 60mm is the minimum
> 75mm is the maximum
Thanks to all,
Robin
