ECU - Question
QC, CANADA
Hello All,
Two question, in the Rabbit/JetCetral Manual they say : "Slowly move the throttle stick from min to max to let the ECU learn your radio".
- Do I have to do this every time I disconnect the battery ?
- If I did it wrong the first time, how can I "erase" this learning and redo it ?
Robin
Robin
My Feedback: (44)
Robin,
No; you don't have to redo every time you disconnect the battery as the I.C.S. has an internal non volatile memory.
Yes; you can relearn if you desire by repeating the steps in the manual.
I hope this helps
p.s. you may want to consider posting specific engine questions in the manufacturers forms
http://www.rcuniverse.com/forum/forumid_139/tt.htm
I hope this helps
