Reload this Page >
Can I Use A Oleo Strut When The Axle Isn't 90 Degrees?
Old 03-19-2002, 11:57 PM
JIMMYTHEEAGLE
My Feedback: (47)
Default Can I Use A Oleo Strut When The Axle Isn't 90 Degrees?
I'M TRYING TO COME UP WITH A SEMI-SCALE GEAR FOR A F-16 AND WANTED AN OLEO STRUT SET UP. MY QUESTION IS THAT THE MAINS COME OUT AT AN ANGLE FROM THE JET AND THE AXLE IS CLOSER TO A 75 DEGREE ANGLE THAN A 90 IN RELATION TO THE STRUT. ROBARTS LOOK LIKE THEY ARE ALL 90 DEGREE, CENTURY JET MAKES A SET FOR AN F-16 BUT THEY WON'T ANSWER MY EMAIL AND GIVE ME ANY MORE INFORMATION ON IT. ANYONE ELSE OUT THERE MODIFY A STRUT OR ARE THEY AVAILABLE AND I JUST HAVEN'T LOOKED HARD ENOUGH FOR THEM? THANKS.
Old 03-20-2002, 12:28 AM
CobraJet
CobraJet's Avatar
Jimmy,
Robart will custom make the bottom portion to any angle you desire. Give them a call. I know Dean Lassek has them made for his big F-16.
Old 03-20-2002, 01:14 AM
grbaker
My Feedback: (29)
grbaker's Avatar
Default Robart struts
I used Spring Air retracts with Robart struts on a small sport model called the Sport Eagle from Sunset Models. To get a wider ground stance I angled the main retract units to move the tires out wider. I bent 3/16" axles to the angle I needed and installed them in the Robart struts. It seemed to work OK. I was flying off grass at the time and they held up well.
Old 03-20-2002, 01:32 AM
A10FLYR
A10FLYR's Avatar
Default Falcon Gear
Mine have the axle welded on at a 60° angle. The retracts are by Air Magic and the struts are by Robart.
Old 03-20-2002, 01:35 AM
A10FLYR
A10FLYR's Avatar
anudder pic
Old 03-20-2002, 01:37 AM
A10FLYR
A10FLYR's Avatar
andanudder one....
Old 03-20-2002, 03:02 AM
Gary Arthur
My Feedback: (29)
Gary Arthur's Avatar
Default century
century (centurion) also have the angled struts
Old 03-20-2002, 03:16 AM
EASYTIGER
Banned
My Feedback: (119)
I had custom ones done by Century for my Crusader, and I was not impressed with the quality. No problem with the angle part, just not very precise units, they use pop rivets to hold it together. Try Robart instead.
