12 FGA Gear Sequencing
I just posted this in the radio forum. I think it may however be more appropriate here.
I am running 2 serperate servos and mechanical valves for my gear and doors.
Is there any way to operate this system effectively via just 1 switch?
Id rather not have this on 2 switches.
What are some of you guys doing about this?
Thanks, Peter
Thanks, Peter
My Feedback: (18)
RE: 12 FGA Gear Sequencing
Check this faq page. I used it for my F-15. works great and is totally adjustable.
http://www.futaba-rc.com/faq/faq-12fg-q1062.html
Marty
Marty
This is what we pay for when buying these radios so why don't you use it? Start with the tips at the Futaba site and work with your radio until you are satisfied. Im using about the same setup and find it useful to use the delay function. The retract can wait up to 3 seconds (if i remember correctly) after the gear doors have opened.
Be careful with the servo slow function since many mechanical systems loose much air if the valves are operated slowly.
Good luck with playing with all the functions in your 12FG.
