1/6 Skymaster F-16 Pro
#77
Banned
RE: 1/6 Skymaster F-16 Pro
The build is complete.
I will run it tomorrow and do the final CG. Then into the trailer for the trip to the Best In The West Jet Rally....[>:][>:]
#81
hi all , i got my F-16 1/6 from sky master but all this photos are differnet than the one i got , do they make a new version?? i am installing 160 SX get cat .
so far i am reading tips about how you building them so any one fly it and talk about how she goes
Ahmed
Ahmed
#82
Ahmed
You will love it such a sweet heart to fly. I also built mine with the 160sx, I only used the two side tanks and the UAT and have a 7 minute timer that I start at takeoff. I land with fuel still in my one main tank which are in series. Landings are very predictable and stable, takeoff's are the same and in the air she is smooth.
#83
thank you very much for your reply well this is calm me down for a while , well i think my f-16 is a new version and at sky master they did not make the new manual , my version is the one which we join the 2 parts of the fuselage behind the main wheels is this the one you got???thanksAhmed
#85
good , so i need help with some tips , under the eninge the white plastic is too hight in mine did you face the same thing , it makes the turbine higher than the mounting rails , the second thing is the streeing servo shuold be in the intake if you made it this way do you have photos for that please??THanksAhmed
#86
The steering servo mounts in the retract frame opposite the air cylinder. I am not sure what you mean about the white plastic is to high, I have nothing under my engine other than the bottom of the bypass and landing gear. I am sorry I told you mine joins the same ,but mine joins in front of the mains.
#89
thank you very much BUT this is not the same version that i have , mine the servos for the steering is in the intack i will make some photos and post it
THanks
Ahmed
THanks
Ahmed
