smart fly turbo regulator?
My Feedback: (44)
If you have a smart fly turbo reg with two batts connected and you lose one, the reg will switch to the good batt and power will continue to flow...
This is why you have 2 switches and check your batteries with something like a volt meter prior to each flight.
For A123 I'm not sure how you would check them if they failed, unless it was totatly dead
My Feedback: (15)
I am looking for a a way to check the regulator function before or after flight. Aside from an inline voltmeter after the regulator, I am not aware of any such "alarm" on the Smartfly. I did like that the Gemini regulator (although for smaller planes) has a light for each "output" so you can tell at a glance if things are working...
I know I can check the battery with a load test, and I do that before each flight to check the batteries....
I wish Jetcat would just put a small generator device on the turbine so we could just switch to onbard power!
Dave
Dave
Dave,
Each turbo reg has two charging jacks. If you tap in to these jacks, it will give you the voltage PRE-regulator. I hook up two C-volts (no longer available) to see what the voltage of each pack is.
After switching to A123's I no longer use the turbo reg, as there is no need. The EQ-10 (and the other new Smart-Fly power systems) havea green light that indicates if the battery is hooked up, it will not however give you the voltage status. An on board volt meter, or checking with an external one, will be the best way to TRULY know. Even then, this will be while the battery is not under any true load so take that in to account too.
It's not IF, it's WHEN [
My Feedback: (198)
ORIGINAL: ddennison
Dave
Dave
NJ
Dave yes there are input LED's for each battery. i have posted info from the instructions for the regulator.
Servo Power LEDs
The servo power LEDs show the servos are getting voltage greater than 5.4V.
If the regulator output drops below 5.4 volts the LEDs will go out. The most
probable cause of the regulator output going below 5.4 volts is that the voltage
at the inputs (Deans connectors) is going below 5.9 volts. Possible causes of
the inputs going below 5.9 volts would be low batteries, wiring that is not up to
handling the current causing excessive voltage drop or bad solder connections
on the connectors.
Receiver Power LEDs
The receiver power LEDs show the receiver is getting voltage greater than
4.75V. If the receiver regulator output voltage drops below 4.75 volts the
LEDs will go out. There are two possible causes of the receiver voltage going
below 4.75 volts. First the load the receiver is presenting to the regulator is
greater than one amp causing the regulator output to droop. This could be
caused by directly plugging something into the receiver that is overloading the
circuit. The second cause of the receiver regulator going below 4.75 volts is
the input voltage to the receiver regulator has dropped below 5.4 volts. This
means the input voltage on the Deans connectors is probably below 5.9 volts
for some reason.
Alan
Servo Power LEDs
on the connectors.
Receiver Power LEDs
for some reason.
Alan
