jetcentral RABBIT, exhaust pipe size?
what size will be best for my rabbit engine, im making a T33 and the rear end in only 80mm wide, CAN be make 90mm but would like to keep the 80mm, how much will the engine need?
Best regards Kasper
Best regards Kasper
FL
Kasper:
Rabbit performs quite nicely with a turbine pipe @ 75mm. 80mm will be just fine. Distance from nozzle to entrance of the metal pipe shoudl be 25 mm with a minimum of 20 mm.
Any further questions, please do not hesitate to ask.
Eric Clapp
from SGT Shaggy PC
Eric Clapp
from SGT Shaggy PC
FL
Peter:
FOD not available thru Jet Central at this time for our turbines.
Revert to the "sink strainer" method from your local Marts or hardware store. Look for the larger mesh in your search.
Thanks for your question
Eric Clapp
Jet Central Micro Turbines
Eric Clapp
regarding the thrust pipe.
i need it MAX 80mm total size in the back and total lenght of 680mm.
is that possible?
is that possible?
Hi Eric
Thought I read somewhere that the ideal diameter was 65mm. Am I wrong?
When manufacturers state the diameter it is always the outside, right?
Regards
Nuno
Regards
Nuno
Eric Clapp
I have several (~15) FOD screens available now to suite the Falcon, Eagle and Rhino, i'll shoot some to you asap. Will hopefully have some for the Bee and Rabbit shortly.
Do you have an inlet size, outer case size and starter OD for the Mamoth as yet? I will then be able to do some calcs to determine mesh size, OD etc....
Cheers,
Smithy.
