Flyeaglejet F-14 first look
#77
RE: Flyeaglejet F-14 first look
ORIGINAL: Rider-60
BTW it looks like they have listened, the web page is updated with CAD drawings for an F35! bye bye ugly X35
#78
ORIGINAL: SJN
looks good..
I hope they cut out the lower parts of the intakes.
On the F-15`s they have left it alone.....[:@]
looks good..
#79
My Feedback: (24)
ORIGINAL: Bob Toilet
Hi
I think my Dremel will handle that massive task,,,
Christian
Hi
Christian
That's a bit of a wise-***** responce, don't you think? Actually, you *can't* just Dremel it out on the F-15 because the bottom of the intake liner comes out at the *top* of that closed off area of the intake, *not* at the bottom. Thus, if you Dremel out that area, you'll be left with the edge of the intake liner being exposed across the bottom part of your intake and with a hole in the intake into the inside of the fuselage. Both of those would look worse than the "mishaped" inlet, so I just left it on my F-15. I sure wish that they HAD done it right on the F-15 and hope they do on the F-14 - it will look much better...
Bob
#80
On the 1/7 F-15E the intake has been corrected at the bottom front. Your picture is from the smaller F-15.
I removed the closed off aerea, and built up the missing part of the duct afterwards. Easy fix, but it would be nice if it was correct from the beginning
I just included the pictures for comparison......looks much nicer when they are opened up....both on the f-15 and F-14
#81
ORIGINAL: rhklenke
Christian,
Hi
Christian
Hi
Christian
Christian
#83
My Feedback: (24)
No i don`t. Have a nice day.
Christian
Christian
As Sonnich mentioned, it looks much better with the intake opened up which is easy to do if you're building it as a kit and then painting it, as I believe he did, but much harder to do if its an ARF. On the F-15 ARF with the Tiger Meet scheme, opeing up that area and "fixing" it so that it would look good is a major task - especially since FEJ doesn't offer any touch up paints in the US for ANY of their kits...
Bob
#84
ORIGINAL: rhklenke
Bob
Bob
#85
ORIGINAL: SJN
Yes, the last 2 pics are of my skymaster f-15....same mistake on that one
I must assume they will fix the bottom of the F-14 inlet. FEJ gear seems to be good in general but they have air cylinder problems but I have always planned on replacing anything that does not work in air system with BVM parts so I don't consider that a big deal. They should buy from BVM all the air stuff including brakes IMHO.
The FEJ F-14 does not have the wing spoilers unless they are planned for released model and not currently included. The Yellow F-14 has them and they worked well. That is a major mistake IMHO because they are really the best way to control roll even though the stabilator is also a taileron or rolling tail in the real plane but only acts as such with wings swept more than 58 degrees. The spoilers are IMHO a good idea when landing/taking off since the stabilator needs to precisely control pitch not roll. I am sure the plane will fly without the spoilers since my JHH/Avonds F-14 I am building will fly that way early on before I replace the JHH foam core wings with a built up set with slats, spoilers, and flaps all functioning.
I am looking forward to my FEJ F-15E when it eventually arrives. I got it in the Isreali desert camo because a close friends grandson flies the F-15 in the Isreali Air Force. A very impressive young man and he does love flying the F-15 and raves about it to his granddad.
I've been grousing a lot about FEJ because I basically have no clue what is going on with my F-15E and I think it is sloppy marketing and sales to post bad pictures or drawings to excite jet model enthusiasts when they have not even flown the plane or put it threw any kind of flight testing. The F-15 was at least tested (without rudders). Just my humble opinion but it seems to me the Liberty is a better process since the modelers are involved. I think that is even more important on a scale model since FEJ could probably create a far more scale model with input from modelers that have a great interest in the "new" scale model they are planning to bring to market. I will bet the Liberty will be a very good model IMHO.
Imagine if they had started that discussion on the F-14. I would bet the new F-14 would have been nearly perfect since there a lot of people on here that are Tomcat fans/nuts and it is much better to get the design correct to start with than having to scramble before delivery and to make compromises modelers buy into.
Enough said since I have to go unpack my BVM F-86 that arrived this morning. here is hoping FEJ steps up to the plate and produces a great F-14 that I want to buy.
#86
ORIGINAL: rhallgarth
But I don't ever recall any manufature doing this. I imagine they have their Cad folks dig up books or whatever they can find, , , then go at it. All hush hush.
Typically, I don't see any manufacturers discussion about an F-35 either.
Compromises:
Whatever they may be, at this point, the moulds have been made.
Can't change too much with the mould without going back to the plug and starting another.
It may, or may not, be a candidate for some scale competition, , , but then 90% of the world would most likely not be buying it for that purpose.
It's still a great achievement.
To get into heavy true scale it takes custom scratchbuilding and dedicated patience like Harold Huff's incredible SU-27.
#87
ORIGINAL: Mike Emilio
If you get a 595 color chip set, you can match it up to just about any shade of anything. When you know the 595 number, it's easy to get the touch-up paint in a rattle can.
ORIGINAL: rhklenke
Bob
Bob
Andy
#89
Very difficult to do after they have a mold made.
Andy
#90
My Feedback: (24)
ORIGINAL: AndyAndrews
rhklenke, FEJ DOES offer touch up paints for their kits. I have personally recieved touch up paint from them for my Tiger Theme F-16. It came with 6 different colors and a bottle of thinner. I don't know why you would say this. Have you actually tried to get some and been turned down? Surely you have a reason for saying this.
Andy
Andy
Bob
#91
ORIGINAL: rhklenke
That is what I was told by both James, back in about June, and one of their US distributers, back in about August. Perhaps they have changed their policy recently, I have not asked since then...
Bob
Andy
Andy
Bob
Well, James was the one who got them to send it to me. They must have changed their policy. This was sent out to me in November.
Andy
#92
My Feedback: (34)
My comments are more curiosity as to how someone can get so many of really tough lines and angles correct, and then miss something as simple as vertical stab angle. The inlets are another story altogether. Those can't be the final version, or someone needs to get their vision checked.
I'm VERY happy though that someone has decided to tackle producing such a beast after the many years of Yellow's 'coming soon' nonsense.
#97
My Feedback: (22)
ORIGINAL: invertmast
I figured since this is twice as complex as the larger F-15 and about the same size, it'd be atleast $1000-1500 more than that one.
You will never see a ARF from FEJ for 6K. Trust me lol.
Even if it is, I think it still sounds like a good price, I think that's less than the Y/A kit cost when it was available, I know I've seen Y/A F14's framed up sell for more than 7K on RCU in the past, this one is bigger, and an ARF. If it was from Airworld or many others it would be a $14,000 price I'm sure. However, since this is all speculation, I won't even pretend to know what it will cost. I'm excited about it, more excited than any other jet I've had
#98
My Feedback: (57)
ORIGINAL: drdoom
Like this paint.
Click for fullsize
Click for fullsize
Like this paint.
Click for fullsize
Click for fullsize
Been there, done that; it's very hard to see with wings swept. (Right Adil?) Since it's bigger, it may be a little easier to see in that configuration, but personally, not again. It is a nice scheme though.
George
#99
And i'm pretty sure the CG change "problem" everyone is so worried about is a bit of a mute point. Their's a few guys on here that have flown the Avonds, and the DCU/Jetmart Tomcats and from what my research has shown, they say the CG change is very negligible and it requires a slight mix. The biggest thing, is once the wings are swept back, their is less rotating mass in roll, so you have to cut the aileron rates Way down.
However, the use of ailerons in swept mode will end up like Manfred Eberhardt`s F-14:http://uk.youtube.com/watch?v=KlFxvUfkSAk
Using ailerons in swept mode locks the model in a dive without any control left, because of any use of ailerons make severe turbulence over the elevators, making them useless.
As some might know, he totalled his first Tomcat due to the use of ailerons in swept mode. The solution is tailerons.
So the ailerons can only be used as flaps when wings are fully extended, no more no less...
I just thought I`d add this, so the prototype can live after the tesing, based on others experience....
Brg
Gudmund
#100
My Feedback: (61)
NJ
ORIGINAL: George
Don't do it Doom!!
George
ORIGINAL: drdoom
Like this paint.
Click for fullsize
Click for fullsize
Like this paint.
Click for fullsize
Click for fullsize
George
As long as you keep it in close and high, its OK but yeah George, it is FUNNN when it goes swept..
Adil
