Wren model 70?
Yes, that's right. The 70s are a version of the MW54 built by us (not available as a kit), and they put out over 7kg. A little less thrust and a little less expensive than a SuperSport, we're widening the range of options open to our customers.
Sara Parish
Wren Turbines
Sara Parish
Wren Turbines
It's not an upgrade that we would usually consider doing, as there is not a huge difference in thrust and it would be expensive, entailing a complete rebuild of the engine. The only time it might be feasible is after a nasty crash, if the engine had to be rebuilt at Wren the guys might rebuild as a 70 rather than a standard Mk 4.
Sara Parish
Wren Turbines
Sara Parish
Wren Turbines
ORIGINAL: Woketman
I'm sure that much of the difference is due to closer tolerances, but are there any hints that you could give us that might allow some of our kit engines to be brought closer to the specs of a 70? Like make mine a 68?
Awww c'mon Mark ... tell the truth. You won't be satisfied with a 68, what you REALLY want is a 69 !
No, that's not possible. I think yours is a Mk 2 or 3? There are quite a few differences between that and the Mk 4, and the 70 is a further development of that. You really need all the changes because they add up together to produce the increase. Making just one or two changes wouldn't make enough difference, and if the engine is running happily taking it apart and changing a few things might actually have a negative effect.
Sara Parish
Wren Turbines
Sara Parish
Wren Turbines
If I remember right the Mk1 was a 12lb engine kit leaving the threads to be tapped and the turbine wheel and compressor needed balancing and had the case made of sheet.
The Mk2 was the same with threads tapped.
The Mk3 had the one piece stainless case and a proper green front cover and still 12lb and was the first of the pretty looking Wrens.
The Mk4 was as the Mk3 but with a fully balanced rotor and bigger compressor giving 14lb.
I'm 100% there were many other upgrades from model to model and I'm sure Sara will elaborate on my rather poor descriptions..
Jason
Jason
My Mk 3 kit was specified as 14 pounds, with turbine wheel, compressor, and shaft pre-balanced...
ORIGINAL: Woketman
No, I thought that the Mk 3 was 14 pounds with a pre-balanced set of spinning stuff.
ORIGINAL: joeflyer
Woketman is correct. The Mark 3 was 14#. They sometimes advertised it as 14+#. The Mark 4 has a number of refinement to get it to 14.5#.
Joe
Joe
ORIGINAL: Gordon Mc
Have to agree with Gordon. 69 is what we want sometimes [8D]
Could´nt recist this one
ORIGINAL: Woketman
Mine is a Mark 3 Sarah. What were the changes from a Mark 3 to a Mark 4?
Thanks.
Thanks.
All our thrust figures are conservative, we give figures that all engines should be able to achieve but most do better.
Sara Parish
Wren Turbines
