Reload this Page >
TBM DV8R ARF and Build Thread with Pictures
Old 01-22-2009, 10:34 PM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Default TBM DV8R ARF and Build Thread with Pictures
Finally got it in! This is the Second prototype. It comes with some changes from the original. PLUS this is a 2 piece wing. It came well packed with plenty of cushion. My first thoughts were, WOW! The covering job is GREAT! Did find out that you have to put the stickers on the tail, Better get it right the first time! Plane comes with CA hinges. The fuse. is also a 2 piece. I am very happy with the build job. I do see some places that need to be built up a little. I will be posting pictures as I put it together and my thoughts. Here are the first pictures. I will be putting a ARTES Super Eagle in for power. Let me know if you have any questions.
ID:	1117174   Click image for larger version
ID:	1117175   Click image for larger version
ID:	1117176   Click image for larger version
ID:	1117177   Click image for larger version
ID:	1117178   Click image for larger version
Old 01-23-2009, 09:28 AM
chcarlos
My Feedback: (9)
Default RE: Its Finally HERE! TBM DV8R
How does the wing attach and isn't there a 3 part wing in the works?
Old 01-23-2009, 10:29 AM
rhklenke
My Feedback: (24)
rhklenke's Avatar
ORIGINAL: chcarlos
I've heard that they were going to do that, but I have to say, I do not know why. Taking the wing off the bottom of the DV8R is the easy part, its hauling that big thing around in 1 piece that is a PIA (I've had 2 of the PCM Models ones). A 2 piece wing solves that problem. Taking on and off two wing halves from a center section will actually take longer and make the wing structure heavier that a 2-piece wing and it just isn't worth the effort IMHO...
Bob
Old 01-23-2009, 11:36 AM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
They are put together with the wing tube. Yes, they are looking at the 3 piece, but don't know if it will work.
Old 01-23-2009, 11:45 AM
chcarlos
My Feedback: (9)
I can't figure out if the two halves are temporarily joined together and then the one piece is joined to the fuse or if the two halves plug into the fuse. There is an opening on the bottom of the fuse that seems to be where the wing would go.
A three piece wing would be nice so that air lines and servos don't need to be disconnected. My Boomerang has this set up and I really like it.
Old 01-23-2009, 11:48 AM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Wing halves go together with wing tube and than bolt to fuse. Yes, 3 piece would be nice but they are thinking that it will make it to heavy.
Old 01-23-2009, 11:53 AM
chcarlos
My Feedback: (9)
Thanks for the info on the wing. I'm on the preorder list and will be following your build. Good luck.
Old 01-23-2009, 12:01 PM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Thanks. I will update and add pictures as I work on it. There are no retracts yet.
Old 01-23-2009, 01:23 PM
rhklenke
My Feedback: (24)
rhklenke's Avatar
ORIGINAL: chcarlos
I don't think that would be possible with a DV8R. If you leave enogh of the wing attached to the fuselage so that the gear can stay with it, it would be very hard to manage - the gear are very far apart on the DV8R. Also, the fuselage on the DV8R itself, with the fins and stabs attached, is very big and enough to manage all by itself even without any wing attached to it. If they do a 3-piece wing, then it will just be the center section of the wing that stays with the fuse and you'll have to attach the airlines and servos on either side. A 3-piece wing isn't worth it on this plane IMHO...
Bob
Old 01-23-2009, 05:04 PM
BCoston
My Feedback: (7)
BCoston's Avatar
Gerry,
Just a quick question, if you are building this to provide feedback for the factory and feedback for TBM why would you not use the CA hinges so the customer can feel comfortable with what they will receive with there kit. Will the final production kit come with Robart hinges?
I know many people do not trust CA hinges but if this is what is going to be offered to the public then flight test data should be used with what is supplied with the kit. Just my 2 cents worth.
Old 01-23-2009, 05:26 PM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Brian,
I agree!! I have the Shock Jet and did a review on it with the CA hinges. As long as they are put in RIGHT there is no worry. So after thinking of what you said, I WILL be using the CA hinges. Thanks for the info. I also agree on keeping the 2-piece wing. Gerry
Old 01-23-2009, 05:36 PM
jlovitt
My Feedback: (41)
I'm also on the DV8R list and will be following along. Thanks for taking the time to show the progress.
Jeff
Old 01-24-2009, 12:13 AM
SinCityJets
The CA hinges on my Boomer XL performed flawlessly at 10mph and 187mph. I personally have never heard of anyone losing a plane or control surface because the CA hinges gave way.
Old 01-24-2009, 12:39 AM
BCoston
My Feedback: (7)
BCoston's Avatar
Gerry,
Any updates on when the production models will be available for customers?
Old 01-24-2009, 11:15 AM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Brian, As far as I know you are looking at fall MAYBE! It takes so long to get the plane from China. Plus TBM is making some more changes to the plane. Gerry
Old 01-28-2009, 03:13 PM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Hey All,
I just got my gear from Sierra! These are Awsome!! I am going to trial fit them to see what, if anything needs to be changed on them. They are really great retracts! Also going to be getting wheels and brakes from them. I had there wheels and brakes on my old DV8R and they worked GREAT!!! I will post pictures Later.
Old 01-28-2009, 08:48 PM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Got started on the retracts. I had to do some extra cutting on the wing, But I do have retracts. The ARF comes with a perforated cut out for there retracts. They are are VERY hard to see and find. You have to heat or push on the covering. I had to make some changes but not alot. Here are some pictures of the wheel well and retracts. The TBM has more of a angle than the Sierra. I am also getting the Sullivan wheels and brakes from Sierra. I did notice that the wheel wells really need to be beefed up. I will be making a well cover after all lines are installed. With the cutout of the well it becomes very weak all around it.
ID:	1122132   Click image for larger version
ID:	1122133   Click image for larger version
ID:	1122134   Click image for larger version
ID:	1122135   Click image for larger version
Old 01-28-2009, 09:53 PM
sweetpea01
My Feedback: (10)
Default RE: Its Finally HERE! TBM DV8R ARF and Build Thread with Pictures
I'd imagine all that would be done for you on the Production Versions I hope.
Old 01-28-2009, 10:00 PM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Yes, The cut outs will be there for the TBM retracts but not any others. I don't think the wing will be reinforced at the wells. You will have to cut out the wheel wells.
Old 01-29-2009, 08:54 AM
tothemax
Looks good gjhinshaw. What brand are those struts?
Old 01-29-2009, 10:11 AM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
The whole thing comes from Sierra Giant Scale.
http://www.sierragiant.com/index.htm
Old 02-21-2009, 12:48 AM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
OK.. I have been in and out of the hospital and now I have two surgrey's in March. So I am going to try and have this jet done before the first one on March 6. I have been working on the wings and installing the servos and hardware. I did buy some finish washers. All went well with that. It was kind of hard to find the hard points. I also started on the elevatores. One of the holes was way off and had to redrill it. I also had to cut down the wood blocks to get them to fit. I also had to find some small screws to fit the cover. I could not find hard points at all on them. I also cut out the retract wheel for the other wing. I am waiting for the air lines and other stuff from Sierra. On the nose whel I had to take out the wardware there and fill it so I could redrill the holes for the Sierra retract. I also added another block of wood. All in all everything is going together good. I am using JR digitals for the most, But for the flaps I am using JR4721. I am also using a smaller servo size on the elevators. If you look at the elev. covers they are not centered, So you have to decide if you want more up ourdo you want more down? I went with more up.
ID:	1140938   Click image for larger version
ID:	1140939   Click image for larger version
ID:	1140940   Click image for larger version
ID:	1140941   Click image for larger version
ID:	1140942   Click image for larger version
ID:	1140943   Click image for larger version
ID:	1140944   Click image for larger version
Old 02-22-2009, 12:01 AM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Tonight I worked on the rudders. Instead of putting them in the fuse. I put them in the stab. Its closer and to me looks cleaner. My first DV8R had them in the stab and really like them there. Here are some pictures. If you can't make out what I did let me know.
ID:	1141766   Click image for larger version
ID:	1141767   Click image for larger version
Old 02-24-2009, 10:14 PM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Default RE: TBM DV8R ARF and Build Thread with Pictures
Worked on the jet today.Put the tiger's on the tail. Not hard to do. Also installed the retracts. You need very little line to the mains. I did have to do some cuttingto get them to fit and to clear the air lines. I also pre-instaled the turbine. I had to do lots of cutting on this part! The rails are set up for a small turbine. I talked with TBM about this and I think they are going to leave them out so the builder can cut them to what they need. Instaled the nose gear, Sierra set me two different lengts of nose gear. I had to use the smaller one. I put the incedence meter on the plane and it came out to +1.2 on the main and on the tail. I do beleave that TBM had theres set at +2. I put the fuse together and used Hysol. Teh fuse went together very well! I also trial fitted the 113oz. fuel tank, MAN this will fit in very nice! Will be able to use velcro straps and is very easy to get too! I trial fited the wing to the fuse and added so bracing to make the wing holders stronger.
ID:	1144214   Click image for larger version
ID:	1144215   Click image for larger version
ID:	1144216   Click image for larger version
ID:	1144217   Click image for larger version
ID:	1144218   Click image for larger version
ID:	1144219   Click image for larger version
Old 03-03-2009, 11:24 AM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Got the control horns in and they are the wrong size, so I have to send them back. Finished the rudders, and put the covers on. I also put chrome covering back on where I had to take the heat tape off. I had to put a piece of hard wood on the rudders due to none being there. Got all the air lines hooked up and working great. I also have been hooking up all the servos and getting them set. Thsy jet comes with some short, medium, and long control links. I found that they all need to be short. I did find out that the flap links are set way to far in. they are almost evan with the servo. The engine plates have been cut and the turbine fits great! I am going to instal a smoke system that will hold 45ozs.
ID:	1149354   Click image for larger version
ID:	1149355   Click image for larger version
ID:	1149356   Click image for larger version
ID:	1149357   Click image for larger version
