 Cheap and Simple ideas that work >
Old 02-17-2009 | 04:38 PM
Default RE: Cheap and Simple ideas that work
If you stand it on end, you can simply cut it off completely.
Old 02-17-2009 | 09:10 PM
highhorse's Avatar
ORIGINAL: F106A
Marc,
I think what they are confused about is years ago the same setup was used but there was either a sintered bronze filter or a pleated filter on the end of the brass tube, supposedly to break up any air bubbles.
As stated above, a lot of people think that the fuel in a UAT tank is usable, when in fact, the UAT fuel should never be used.
If, after a flight, you find you had to use the UAT fuel, either get a bigger main tank or shorten your flight times.
BRG,
Jon
OK guys, I feel like this is turning into an entirely different thread, BUT I want to say that OF COURSE I know that the fuel in the trap should be CONSIDERED unusable etc (who in their right mind wants to eat into the last TWO OUNCES or fuel? Duh! )...that is, however, no reason to deliberately MAKE IT SO. The "get a bigger tank or shorten your flight times" concept, besides falling into the "state the obvious" category completely ignores the fact that air can get into the trap for a lot of reasons, not just cus someone can't tell time. If an airleak in the system, main tank clunk problem or some other malady introduces air into a trap without a bubble-eliminating sock or clunk then the "air eating/flameout-preventing" CAPACITY will be reduced a full 50% in the configuration shown above.
Not to be disrespectful at all since I'm certain each of you has more experience than me, but since there are also a lot of very experienced folks who DO see the value of a traditional UAT type of device I remain personally unconvinced regarding this particular cost saving idea and will err on the side of caution.
Old 02-17-2009 | 09:37 PM
erbroens's Avatar
Instead of buying a new car, keep the old one and spend the money in a new jet.. this could also help avoid having eventual relatives borrowing your money or better yet you borrowing money from the bank!
Enrique
Old 02-17-2009 | 10:04 PM
timrob's Avatar
ORIGINAL: erbroens
Especially since you US folk just spent about $800 billion today! Ouch that's a lot of money.
Tim
Old 02-18-2009 | 04:33 AM
icepilot's Avatar
" besides falling into the "state the obvious" category completely ignores the fact that air can get into the trap for a lot of reasons, not just cus someone can't tell time. If an airleak in the system, main tank clunk problem or some other malady introduces air into a trap without a bubble-eliminating sock or clunk then the "air eating/flameout-preventing" CAPACITY will be reduced a full 50% in the configuration shown above.
I guess the best money-saving tip here would be to build and maintain your fuel system in such a manner that air does in fact NOT get into the trap - when I land, I never
have more that a small "drop" of air in my hopper tank, if I should ever see that there is more than that, it's about time to go over the system again. If you have a serious
air leak, no hopper tank or UAT can save you from a flame-out for more than a few seconds...
That also goes for all other systems onboard - the air system, batteries, fuel, retracts... build it and maintain it well, and you will save the entire amount that you will loose
if you don't!! Don't accept "a small air leak" in your retract or brake system, don't fly with batteries that are old or worn, don't fly with retracts that fail every 3 or 4 times
you test them, and you will save a lot of money!![8D]
Tor
