 Question for Weatronic gurus >
Old 02-20-2009 | 10:38 AM
Default Question for Weatronic gurus
I'm trying to set up the RX-based mixing on my 10-20R. I want to select 2 output channels for ail, 2 for elev, etc. For some reason, the prog will NOT allow me to assign 2 output channels to a single input channel if those output channels are exactly 8 apart. So, for instance I can assign 4 & 11, or 4 & 13 etc for elevator, but not 4 & 12. Similarly for any other combination of outputs - any spacing apart oyther than 8 seems t obe allowed. I really want 8 if possible, because then that allows me to have a 'row' on the RX per mix - the 2 elev servos plugging in next to each other, the 2 TE flap next to each other, 2 LE flap ... it seems ludicrous if this is prohibited for some weird reason.
Any advice from the gurus ?
Gordon
Old 02-20-2009 | 01:34 PM
Selleri's Avatar
Default RE: Question for Weatronic gurus
Afraid it isn't possible and it's stated in more detail in the manual IIRC.
It has something to do with servo synchronization.
BTW There is a support forum here for Weatronic > [link=http://www.rcuniverse.com/forum/forumid_482/tt.htm]http://www.rcuniverse.com/forum/forumid_482/tt.htm[/link]
Old 02-20-2009 | 01:48 PM
ORIGINAL: Selleri
OK thanks - I had looked in the manual under grouping etc., and saw nothing.
Sounds like a really stupid restriction ... kinda makes it sound almost like the Weatronic software is controlled by Bill Gates !
I guess I need to start over with the channel assignments. What a PITA.
Cheers,
Gordon
Old 02-20-2009 | 02:43 PM
Tried posting in the Weatronics forum to see what explanation I get..
Old 02-20-2009 | 03:30 PM
Selleri's Avatar
ORIGINAL: Gordon Mc
I scanned quickly through the manual > check page 14, paragraph 2, last line.
