I will never use Lipoly batteries again
#52
RE: I will never use Lipoly batteries again
Charge and store your LiPos in a terracotta pot, not in metal containers (too risky ! ).
I have converted almost completely to A123 batteries after I had to dump about 15 Lipo packs in one weekend. They're fun but their lifespan is too short (and they're dangerous).
I'm very impressed with A123, they are extremely fast charging, by no means critical, deliver an incredibly high constant power, less expensive,...
They are only a bit bulkier&heavier and a bit less Volt/cell, but the rest is pro A123.
I even use them now to run my Kolibri turbines (in 2S configuration > same single pack for RX and ECU !), receivers, and JetCats.... next to the applications in small electric models of course.
No more NiCad, NiMh, Lipo, LiMnO,... I prefer A123 !
Nicolas.
Nicolas.
#54
Murphy's law is powered by Lipo
No, seriously, they are not really impact resistant... Do a search on Google and YouTube...
#56
There's always a risk... suppose they are a little damaged at the inside and the seal breaks inside a cell...
You can compare the idea of the risk at rest with an inflated air balloon with a weak spot on the surface somewhere. Will it hold the air pressure ? Yes. Is there a risk it will burst, even if it held for a while ? Yes.
Our cells are not used in a hard shell casing, hence always more submitted to handling/impact risk.
#57
Sorry for your buddy Mark, hope he is still going to Wang. See you there.
It has me amazed why anyone uses lipos in a turbine jet anyway. Different batteries, different applications. Sure, lipos have revolutionised electric powered models with their high energy density but is it needed in any other type of model?
Have they just become 'fashionable'? Most jets are flying bricks anyway so a couple of extra ounces for batteries is not an issue.
My thoughts too. I have just bought a couple of Eneloop packs & try those. The advantages of ni mi cells without the self discharge problems. Perhaps the best compromise for me. - John.
I think I will just stay with nicads, only had one problem in 22 years.
#58
Sorry to learn of the loss. The Avonds F-15 is a great plane and my experience is only with the old version! Been using Duralite Li-ion packs with safecharge and the Duralite charger and voltage checker since July 2004 because they have a warranty. Of the seven packs I own one has failed because of a deep discharge below 5.5V. Otherwise no problems. I charge these in the planes but like others would never charge a LiPo in plane. Even the 14MZ battery goes in a fireproof bag for charging.
#59
My Feedback: (85)
If you guys knew how some (most) of these (LiPoly) packs were made you would steer clear of them...Only a thin "Mylar" type film separates the "plates" and without a hard outer cover of some sort to protect the pack, these packs are very susceptible to being damaged...
And yes...Just sitting on the shelf, or in your model, these packs can self destruct without warning...You never know if the pack was jostled just enough to put it on a course of self destruction....
Kevin
Kevin
#61
My Feedback: (24)
WI
Nico's comments about the Terracota planter is great. Gonna get one today.
BV, Tam, and now Shulman Aviation and other purveyors of hair dryer technology are not going to be happy about all this bad LiPo press. Forget about little RX and ECU Lipo packs. Those 40C-5S2P-6500maH packs, big as 2 salami sandwiches stuck together, are weapons grade when it come to an inferno if one of them lights off during a recharge gone wrong or rupture after a crash. Used with caution though, they have proven quite reliable and safe so far, but even a 1/1000 chance of a LiPo fire during re-charge could be disastrous inside your house, trailer, or car.
So.....Bottom Line from my experience which includes 1 fire from a post-crash rupture of a Li-Ion and unexplained overcharge on a Duralite Li-Mn which expanded to 2X normal size, but did not burn or rupture, using a dedicated Lithium charger, which has tested totally normal since the incident
Never charge unattended, preferable never inside the house
Never bury your Lipos in your plane where you can't rapidly get them out if you elect to charge them inside the plane
Never use tie wraps to tightly fasten Li-Po's....use Velcro and HD Double sticky tapes per Kevin Greene's comments. The separators and outside case are fragile.
Always check and double check your charge algorithm before pushing the start button on the charger. Nothing will destroy and probably light off a Li pack faster than a NiCd or NiMh algorithm. Preferably use one of the dedicated Lithium-Only Chargers on the market.
And Never Crash you Planes...
And almost forgot.....Switch to A123 whenever possible.
#62
...................but Tom, can anything be as good as these A123s. They seem too perfect, there MUST be a problem ! (using them extensively now, for both ECUs and Rxs. !!)
Regards, David Gladwin.
#63
My Feedback: (24)
WI
Hi David:
The only problem I have had retrofitting has been the modest increase in size of A123 over Li-Ions. In some of my tight installs with custom cut battery holders, they just don't fit, and I am too lazy to re-do the layout. I think that is holding back the Sparky's from jumping in as well. When you make up the equivalent of a LiPo 5S-2P 6500 in A123, it won't fit in the first generation of Hi Power EDF's out there at the current time.
Tom.
Tom.
#64
ORIGINAL: Kevin Greene
Kevin
Kevin
Come on guys LiPo's are not that dangerous its the abuse that they get that makes them unstable and a bad charging regime.
Jet Cat cannot convert any ECU's prior to Serial No 2350 to use A123's and if you have kero start you have a problem, Nimh can not supply enough power for the ceramic plug without going to silly size's.
Anyone used a JetCat ECU with A123's without having it converted?
Mike
#65
No problem at all, just use a boost battery for starting. I connect a Duralite LiMn battery in parallel during start of my P70
kero. , disconnect when start complete, go fly !
Use of A123s on unmodded Jetcat Ecus MAY cause failure , of my two 160 ECUs , one was OK the other failed. soon fixed by JC. Both are now modified and work perfectly on 123s
and Tom size must be the only problem, slightly increased weight even allowed me to remove some lead from the nose of my Hawks. Can't belive how fast they recharge too, using the CellPro from SinCity jets. THE battery for RC use.
Regards,
David .
Regards,
David .
#66
Due to flight restrictions at my club field, I have to start on the patch, I am already carrying an extinquisher, a Tx, fuel overflow and you are asking me to carry somthing else as well, no chance.
I will ask again, has anyone used A123's without converting an early ECU?
Mike
Mike
#68
CO
ORIGINAL: mr_matt
Hi Mike,
There have been many people that have run 3 cell A123 with JetCat ECUs without problem, but it is too marginal. Many have had failures.
In any case, JetCat USA can do the mod on any ECU, the charge is US$25.
Hope that helps,
Hi Mike,
Hope that helps,
Lee
#70
ORIGINAL: BaldEagel
Never leave your house with your car still in the garage, they have been known to spontainously combust.
Mike
Kevin
Kevin
Mike
Almost every cell phone, PDA, laptop computer and other small electronic gizmos that you use and charge everyday in your house and or car have LiPo batteries.
Do you really think that the lawyers would let that happen if they were all that dangerous.
When used correctly they are quite safe.
I have not seen many installations where the are used correctly.
#71
ORIGINAL: Silver182
Matt.. you have got to explain why (3) 3.6 volt cells would be supplying marginal voltage / current for the ECU? From what I have heard (don't know from direct experience) the A123 battery cell is the best battery available at this time. Please comment.. and ask Bob he must have some direct knowledge about the batteries also.
Lee
ORIGINAL: mr_matt
Hi Mike,
Hope that helps,
Hi Mike,
Hope that helps,
Lee
IIRC, the issue is that a freshly charged A123 can be too high voltage and damage the ECU.
Gordon
#73
Actually I'm quite surprised of the contained meltdown of this incedent and find it an improvement of LiPo technology of years past. Just 4 years ago the photos show a complete portion of house, garage, gone. I've been around a few Lipo meltdowns and to date have never seen the intense fireball of flames so popular with the LiPoSack promo vids.
I have been using LiPo since their being mainstream and find them to be the biggest source of Urban Legends than any other Rc item.
There are videos on the web that show an #11 exacto peircing one without incedent, I've witnessed a freind purposely drive a 1/16" music wire through one completely.
A freind drilled a 1/16" hole on his model and went a tad to much and into a new TP Lipo which DID NOT explode in his face but rather started a super generating heat swell in which he promptly removed and threw it into an open area.
While it is true TP packs are premium and hold voltages per cell closer, there are other items they dont accel in, Fact is I run Rhino cells and can discharge them to over 160 deg and they will not swell, A ThunderPower will swell around 140 deg. I was exxlusive TP 3 years ago but now exlcusive Rhino. I do charge all my Lipo's with an active balance charger adapter from Graupner to my Shulze MCduo latest software.
Charging in a model is absolute no no RULE #1, All incedents of fire IMO, a charger is invovled and ASTRO or MRC are most involved variety.
IMHO LiPo, "DO NOT" spontaneously combust, One item proven a contributor of this phenom is that DEANS mini polarized style plugs when left dangling in a model or batteries in a mass storage enviroment, CAN actually short circuit themselves and dead short a battery as the male pin can insert itself across the female and male pins of a close proximty plug of the mini polarized, I always put 5/16" vinyl caps on my mini deans ends. This phenom happened when a LiPo was left in a model for the ride home and the mating mini of the close proximity of the ESC made it short circuit. I never leave them in the model after use as well. And I cringe when I see the guy open up a case, box, container of all his LiPos with those dreaded minis in close proximity to each other..02
#74
Hello,
Just to say that in our "indoor flying" local club, people use hundreds of LIPO battery..
I have never seen one of them explode of burn etc in 3 years !!!!
What you have to do is charging at 0,5C with a good balancer.
But yes there is always a risk....risk is everywhere...
JeanFi
JeanFi
#75
My Feedback: (21)
I'll preface this with "if you haven't crashed you haven't flown." I have flown a lipo powered jet straight into the ground and accordioned the battery into mush without incident. I repeated this same procedure with a slow flying model and actually split the casing in several places on a zippy rhino pack with no heat, swelling or fire. I have another pack that when bought new reeked of lipoly chemical smell like it was venting. So although these are all extreme examples, it just depends on how you tear up a pack and if there is a good short, caused by wiring or a damaged cell etc. It would not be a good idea to charge a pack that is not balanced unless one knew the cell voltage and capacity for a particular pack. That is asking for trouble, no matter the chemistry. I can remember when a lot of folks were complaining of NIMH fires as well due to the fact that they were charging them at higher than C rates. They couldn't figure out that charging a pack to the point of overheating was not a good idea...
MACE
MACE
