 Help: Skymaster Brakes O-ring >
Old 03-31-2009 | 07:41 PM
Edgar Perez's Avatar
My Feedback: (13)
Default Help: Skymaster Brakes O-ring
Hello All,
A leak in my F-18 wheel brakes have been confirmed to be due to damaged o-ring. Brakes are Skymaster. The hub has one smaller size internal o-ring and another, larger one. I need replacements for the larger one.
Both of my main gears brakes o-rings are damaged (not sure how come both got damaged at the same time!)
Anybody know the diameter and thickness of the o-ring? I'm thinking must be metrics ones...
I will check with Skymaster-USA if they have some. Others?
Also, what is the axle diameter?. Got a small bend in mine and want to replace. Also think is metric...
Old 04-01-2009 | 05:55 AM
RCISFUN's Avatar
My Feedback: (44)
Default RE: Help: Skymaster Brakes O-ring
Edgar,
One of these is a must for your tool box
http://www.harborfreight.com/cpi/cta...emnumber=47257
