Hotspot Retacts
CA
JetCat USA has the new version of the original retracts but they have aluminum shells now and the brakes are the flat o-ring type. They work great and do not require any modifications to install.
Hi,
Suggest Springair 400 series with 7/16" Robart legs on the
mains fitted with Intairco brakes (3 1/2"), Intairco noseleg and
2 1/4" nose wheel, just a suggestion but replace the lite ply
nose gear mount side plates with good ply using the originals
as a pattern. The original Graupner gear lasts maye 25-30
flights depending on the surface you fly from ........
Mike
Mike
My Feedback: (31)
I want to thank everyone who has replyed and now I have a better Idea of what retracts to use. I just got my turbine Sunday, its a SIMJET 2300AES that should push it nicely I am hopping to have it done in a month or two. I will post all my results on here when I finnish.
Dave
Dave
